oem a4 header or generic header?
    which one would you prefer?
    i have the generic header but after 3 years it now has a burnt look to it. im thinking of going back to OEM but a4 header (since i have a a1).
    is that a good idea?
    cb7 rebuild coming soon!
    Do you have the single inlet flex pipe used on the A1? The A4 exhaust manifold is a 4-2 design and requires a 2-1 flex pipe (A4, A6) and the 02 sensor is located on the flex pipe ahead of the cat instead of on the manifold itself like the A1. If the header still works, there are surface treatments that can improve the appearance. Check out Eastwood auto restoration products.
      both seem to flow good , so i would go get some high heat temp . paint and clean the header and re spray it . but as stated above , if the header has no leaks , then why change it
        right now i have the generic no brand header (4-2-1?). i just thought an a4 header would be better than a crappy header from ebay.
          If you have a 4-2-1 header, switching to a F22A4 manifold (which only goes from 4 to 2) will also require a new flex pipe and relocation of the 02 sensor.
            i figured that... -__-
            the a4 flex pipe is a direct bolt on though right? o.O
              If the header you have now is working properly (no leaks) then there's no point. The A4 header won't be any better (possibly a little worse in terms of performance.)
              People generally say the A4 piece is better, because there's no need to spend $100 on a cheapie header that isn't going to give much of a gain over what the A4 has to offer. However, a newer cheapie header is usually better than a 20 year old OEM one that's about to fall apart.
                The a4 would bolt right up to your cat, but if I were you, I'd leave it as is w/ the aftermarket one, it's perfectly fine!
                  ceramic paint, here i come!!
                    If all you care about is how it looks then get used to pulling it and re-doing it often. Or send it out to get jet coated or something like that.
