Distributor problems, oil leak
    I recently picked up a CB7, and the ignition coil is burned out and so is the distributor cap. Also, oil leaks from the distributor. I was wondering if i should buy a whole new distributor or just the cap and the ignition coil? and if u suggest just the cap and ignition coil, how to stop the oil leak?
    rebuild it. replace the inner seal and the o-ring on the end.
    COUPE K24
      o ok, so buy a new cap and ignition coil and replaces the seals and it will be all good, also do u know the firing order on the cap?
        COUPE K24
          thanks Alot
            Replace O ring. Take off the Dizzy; but before you take off the Dizzy. Mark your timing. Replace Cap/Rotor..
            MY MRT
            http://www.cb7tuner.com/vbb/showthread.php?t=178936
              where should i make the marks exactly on the three bolts hold the distributor? and also is it normal for the rotor to have play and not fit snug on the shaft ?
                A little play is ok, but excessive is no bueno. You can mark your timing by marking behind the bolts, on the other side of the dizzy.
                  any ideas on how the cap got like that?
                    thanks dj, and im not to sure the guy i bought it from said it might have happened from the oil getting in the cap or the ignition coil going bad
                      Np!
                        Does anybody no where i can get the internal seals for the distributor, my local auto parts stores does not have them, any web sites i can order them off mabey?
                          Best to buy from Honda dealer.
                          That way the part will fit and it will last.
                          Besides its only an "O" ring and will not cost hundreds or even tens of dollars. So your savings is really only very minor but it will give you peace of mind that it will fit and last.
                          Goodluck with it. I may need to do this also when I find some time and not get lazy when the free time does presents itself.
                          Rides:
                          Accord
                          92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
                          96-AUDM-2.2 VTiS- Heather Mist
                          CR-X
                          88-JDM-Si- Black
                          CR-X Del Sol
                          92-JDM-SiR "Transtop" Motegi Edition - Silver
                          95-JDM-SiR "Transtop" Daytona Edition - Silver
                          92-JDM-SiR "Transtop" - Black
                          Prelude
                          91-JDM-Si-4ws "Si States" - Phoenix Red
                          91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
                          91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
                          91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
                            Besides it only an "O" ring and will does cost hundreds or even tens of dollars. So your savings is really only very minor but it will give you peace of mind that it will fit and last.
                            what? OP, the inner dizzy seal is NOT available from Honda, it's not a serviceable part. you have to order from an aftermarket company. i don't know off hand of a site that carries it, but you can try www.rockauto.com
                              Here's a DIY thread on this exact topic: http://www.cb7tuner.com/vbb/showthre...utor+leak+seal
                              Here's 1 website that hopefully should still have the seal, taken from DIY (read entire thread, there's quite afew links)
                              http://market.autopartsfair.com/hond..._65416nok.html
                              At least for the F series sohc, I take a small straight egde + scratch awl and scribe a line across the top ear of the dist to the rocker ass'y on the head. That's prob. the most accurate, scribing the washers works too, but the washers can move slightly around the bolts.
