Color of NGK wires?
    Color of NGK wires?
    This is a very simple question I am not sure about but do NGK wires only come in blue? or do they come in other colors as well
    Thanks for any feedback
    The ones I pulled from the junkyard are blue. What color are you looking for?
    MRT
    sneaky motherfucker
      I am looking for red, but the only ones I find online and stuff are blue
        NGK wires normally come in blue or the common black, like MSD come in red. If you are looking for a different color than that, Google colored spark plug wires for different brands.
          Thanks , Do you recommend any specific brand? this not for racing purposes just to upgrade a few parts on stock F22A6
            Blue, ngk, yellow, accel, red, msd
            Go ngk.
            wat?
              Me personally I prefer NGK wires, but MSD wires are pretty good also.
                Go ngk.
                yea I was looking for a red wire set because my valve cover is red and so is the intake filter, the only thing blue is the optima battery lol
                  You can always cleanly wrap them in red electrical tape. Pull each wire tight in between 2 objects and wind the tape on in a consistent and even pattern. I don't mind the look of it but that's just me.
                    Isn't the blue optima battery a marine battery?
                      Yea it is lol but at the time I needed a battery and got the Optima Blue Top for 50$ almost new So I got it and it has yet to fail on me
                      But I think I may just go with the NGK blue anyways just because MSD wires are about 100$
                        Go ngk.
                        I know accel's come in many colors yellow is the trade mark, but i know they come in black, red, and with braided shields.
                        Honestly they are tons of different colored wires out there (Taylor, Accel, MSD, Summit, etc etc) just need to check for your application. I've always had good luck with Accel's and if i recall back a few years ago a magazine did a test on most aftermarket wires and accel was their best bang for your buck. Cheapo's at any parts store should be just fine you can by colored sleeves atleast you used to at summit.
                        02 Crv
                          NGK and Sumitomo wires are the best performers (Sumitomo being the best... but they're black only... they're OEM.)
                            Taylor has red so does accel for our cars and all under $50-70 and summit has MSD's for around IIRC $90.
                            02 Crv
                              http://www.ebay.com/itm/90-93-ACCORD...#ht_8083wt_905
                              I found these but I don't know if that is legit NGK wires?
