is it safe to just bypass the aic valve if my idle is fluctuating? and if its isnt how can i fix it? ive tried cleaning it, messing with the fast iac. HELP!!! :{(
bypassing my iac.
Got any more info? I would not bypass it personally.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
why do you want to bypass it?
bypassing it would actually give you a fluctuating idle, in most cases, probably worse than what you have now. bypassing it is mostly for racecars because they need colder air. you need ambient air.
Rush
Originally posted by DarkcloudBought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
Originally posted by bmxicansdso you got a boombox, sunglasses and rosettta stone?
Have you looked into other symptoms of a fluctuating idle such as air in the coolant?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
My IACV,FITV,Air boost are all bypassed no fluctuation problems. But if the IACV is bad (Can check the plunger with a 12v source) then it will still fluctuate. The only other way i know of is to have it eliminated through a tuneable ecu.
Also air in the coolant system will cause fluctuation issues, so try bleeding the system.Last edited by SOHC-FTW; 10-23-2012, 08:37 PM.
02 Crv
Quickest way would be a business card/thick card stock inbetween it and the plenum. It can be remotely located aswell as long as it's hooked up to the harness and w/ a block plate on the plenum, coolant isn't necessary either. Bump up the idle abit to compensate for extra loads like heat, a/c and lights.
It's reving up from 1000 to about 1500 and going up and down. But sometimes it does it and sometimes it does really bad. If I let it warm up it doesn't do It. But when I get off the highway it's does it about 5 or 6 times and the idels around 1000. I've try cleaning bothe the aicv and fiacv and the I tried turning the top of the fiacv and cleaning it. Should I just replace them? Or try bleeding it?
Why are you repeating yourself and asking for someone to repeat what they just suggested to you? Why don't you just go try it?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I recommend searching the diy section for key words = idle fix. Search in "titles only" to narrow it down, you'll find what you need.
If after the above you still have an erratic idle, replace your FITV with OEM ONLY from www.hondapartsdeals.com. After this, adjust your base timing and base idle (search for the threads). If you have any issues after all of the above come back to us with questions.My Member's Ride Thread
