Hello all and thank you all in advance.
I'm going to be doing a full H swap in February. I know there are probably tons of info on this forum. I would like to hear from anyone who has experoiance with this actual swap. When I do start the project, I will post all that is done.
First- I have the F22A motor with an auto Trans. JDM Depot here in jersey will be where I'm purchasing my motor from. I want to make it manual Trans and try to convert it to OBD2 by using the 97-01 prelude H22 motor. Any feedback will help.
I know I have to buy the oil pump as AEM. The motor will be complete with ecu and harness. I know I'll also have to move some mounts around. I have welding equipment so that won't be an issue.
On another note, if turbo was going to be an issue, if lowering the compression would be recommended. Changing pistons, reringing sleeves or just resleeving. What pistons, or size would work best. Any help would be helpfull. I'm doing all my research now so by the time tax time comes around I can have a game plan.
