I know its larger but want to know if bolt pattern is the same. thanks
Will h23 throttle body fit cb plenum?
No, it won't. The bolt pattern is different and there are provisions on the H22/H23 throttle body for the FITV and it wouldn't have anything to mate to on the plenum.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
^An OBD2 plenum and t/b will work. The map mounted t/b can be used aswell, you'll just need to make an adapter harness:
http://www.cb7tuner.com/vbb/showthre...t=79283&page=2
Do you currently have an IAB manifold or at least the runners like this?:
http://www.cb7tuner.com/vbb/showpost...3&postcount=16
Here in the states at least, you can/could delete the black map box if you relocated the orig. map or run the map on the t/b AND have an ecu that doesn't look for egr. The rest of the components in that box are for egr and with the stock ecu you will get a code 12 if you ditch them. Not sure if your CB has egr but something to think about or experiment with.
thanks for great info. Yes I have IAB. I'm deleting egr also. What should I do not to get 12 code? Connect egr wires together to close circuit or put resistor or something like that? Here is my build:http://www.cb7tuner.com/vbb/showthread.php?t=196726
^Didn't realize it was you but I do remember reading your build, love it Good question, I suppose resistors could be utilized but I wouldn't know anything about that. I do know that the accord and prelude ecus look for egr, so if anything egr related is unplugged, you get a code. Civic and integra ecus do not look for egr, when I went w/ a chipped p06 civic ecu, I could finally ditch the black box and my tucked away yet plugged in egr valve!
