removing heat shield over exhaust pipe
    any way to do this without removing the exhasut pipe itself? i got the two side bolts off no problem. it's that center one right above the pipe that is a pain in the butt.
    i'm removing it so i can change my parking brake cables.
    thanks in advance!
    It would be a lot easier in the long run if you removed the sections of pipe that are in your way, what's a couple more bolts?
      yeah that's what i figured. was wondering if someone had some magic trick they'd be willing to share. it's rusted pretty badly, so i'll tread carefully.
        hum, I just removed mine.. and the middle screw was not attached to it.
        (it was there but there was a hole in the shield to let it pass) I think the shield might be stuck under the ac/alternator mount.
        Or maybe mine was just too rusty...
        if you need to remove the manifold, might be a good timing to clean/switch gaskets
        have fun
          I'm not a huge fan of those shields, I removed all of them w/ the exhaust fully intact, it is possible. I think a few times I used tin snips to get them out but you should be able to wrestle them out, that's if you plan to not put them back in!
            guess i didn't explain myself well enough. the pipe is rusted out pretty bad, especially where the bolts are- near the muffler (it's original). guess i'll try and drop it down by removing the whole thing from the rubber holdings.
              I was trying to take this off my self as well today, got all the bolts out easily with a lil pb blaster but I couldn't wiggle it out. Looks like the power steering/alternator bracket piece is in the way, so is my ac line.
