I took my car battery out of my 1992 Accord and replaced it and noticed after that my speedometer stop working coincidentally. If my speeds gets up to over 80 km/h, I notice the speedometer tries to work, but it just jumps around. Any idea what could be the cause?
1992 Speedometer not working
Did you do ANYTHING else besides a battery change?WWW.JDMCONCEPTS.COM
Keep .It. Simple. Stupid =K.I.S.S
The vehicle speed sensor (VSS) provides an alternating 0 - 5 - 0 volt signal to the speedometer, odometer, and is used by the cruise control. If they all act up when the speedometer is not working, it is likely the VSS or the wiring to/from the VSS. If the odometer and/or cruise work correctly when the speedometer is acting up, it is not the VSS. If it is only the speedo, it can be replaced in the cluster.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Thanks for all the feedback, I'll check all the suggestions this weekend and hopefully it's something simple. To answer the question about if I did anything else other than change my battery, NO. All i did was change the battery. I guess things are going to start going more frequently as it's a 1992.
