Sorry for not getting back with you yesterday, I had some out of town business to tend to.
What gasket are you referring to? There is only 2 o-rings and one seal regarding the dizzy. Dizzy cap o-ring, the o-ring you already replaced and the seal you just ordered. As for the dizzy cap seal you will get one with a new dizzy cap which is pretty much a necessity at the point where you are at along with the dizzy rotor. Parts stores will have both and are good to use, you don't need anything special like OEM or anything. I advise you to change the dizzy rotor because you will likely have a little bit of a tough time removing yours when you go to replace the seal and it's not uncommon to damage them when removing.
I like Autozone myself, the cap is $16 and the rotor is $7.
There is nothing unsafe about driving it in its current condition as long as you check the oil very frequently. The amount of oil you are losing is minimal but I would still check it every time before you get in it to go somewhere. Just to be safe.
You are very welcome and that second DIY should serve you very well.
They are tough to find. I know the Honda dealers here have them and I find it odd that the one you went to didn't have it.
Let me know how it goes!
Originally posted by greenquark
View Post
View Post
