Going to keep this pretty short. I completed a full rebuild of my stock motor, the F22A6 on a '93 sedan, 5 speed.
Last week, my tach started to jump around, and I got engine code 20--Electrical Load Detector. All other gauges are running fine. It occurs about a minute after the car is running, but I'm not sure what is triggering it aside from just turning it on. My best place to start, I think, would be the engine speed sensor, which I'm not sure where it is. There's two sensors underneath my distributor, a red one that has a single wire leading to the harness, and another one that has two wires that lead to a pair of striped ones on the harness. Unfortunately, the previous owner damaged them and instead jury rigged two connectors together.
I know it has something to do with the end connection because the tach was working fine for the past several weeks after the engine rebuild. Any insight would be appreciated, but I am NOT looking for the VSS located on the top of the transmission.
Edit: I forgot to mention while the tachometer jumps around while in gear and out of it (Bumps on the road seem to exacerbate it out of gear), she does drive and doesn't have an issue running. I have a code for the EGR as well, but that's a different issue.
