93 se key wont come out of ignition
    As the title states its a 93 but the key wont come out, i have two keys for it one is in the ignition and i cant get it out, i have no idea, could it possibly be because the used to be an auto and is now a manual?
    Did the key work before? Just to be sure, the wheel isn't cranked to one side so the that the steering lock is binding it up? The automatics do have an interlock so the key can't be removed unless the transmission is in park (and maybe neutral).
      Yeah, it used to come out then one day it just wouldnt
        PB Blaster will help get it out. Then I'd clean it out, and lube with graphite.
          Graphite is a bad idea, use white lithium spray, the graphite will clump up inside the lock cylinder all around the springs and tumblers and impede movement of them. Also if you have lots of keys and junk on your key rings swinging from your ignition as you are driving down the road, then you are causing damage to your lock cylinder, the tumblers are brass and wear easily against the key. Get a carabiner and key all of your key sets seperate.
          Under Construction​​​​​​​​
            What shape are your keys in?
              The fact that you said it use to be an auto makes me think that the switch that makes the car think it's in neutral may have gone out and it may think it's in drive which I don't think the car will let you take the key out. But I'm not very familiar with automatics.
              ~Nick~
                I was gonna ask the same thing...don't the old tumblers hate super worn keys? My friend @ the honda parts dept used to always mention that brand new keys straight from honda are the way to go. Since it used to be an auto, is the car still wired to be in park? Did that connection become broken in some way so the car is no longer in park?
                  The shift interlock is a cable driven type lock from the gnition to the shifter assembly, if the car was converted to a manual them the interlock cable was most likely removed from the ignition, femoved the 2 piece plastic shrould around the steering column, 3 phillips head screws underneath, and look to see if there is a cable running into the bottom of the ignition switch
                    http://www.cb7tuner.com/vbb/showpost...&postcount=104
                    On the conversion for the CB's the GRN/WHT + BLK sets it to park, so I was wondering if that was still connected properly.
                      good link, yes check that first
                        Keys are in good shape not the greatest but not too worn
                          Ill bring it to the shop and start with this, much appreciated ill update when i find out if anyone is really interested lol
                            ^Did you check my link? Is the car still in PARK?
                              Ive had a few things come up starter went out on the catalina which is my daily driver and a few other things so im broke and havent had much time so ill be checking in the next day or so, i dont know if its in park or whatever, it was swapped to manual so ill have to check that out, im kinda toying with getting a clean cb9 wagon and swapping my turbo motor into a wagon. But idk yet
