how to remove C/C P/S?
    I never use Cruise Control..since removin reduce weight..i want to discard c/c but in haynes dont show that..anylink out there ?? btw if theres link to remove P/S let me know
    thnx
    MY 1n2 CB7
    For C/C just unplug and unbolt it (you do know what it looks like correct?) and I'd prob. just leave the cable alone and tuck it somewhere in the bay, you may not want to cut it
    For the P/S, you can 1st take the belt off and see how it is, and then you could unbolt the pump and bracket, and loop the high pressure feed line and the return together w/o modification. That'd the simplest way and you could put it back whenever.
    Dan
      Dont forget to plug up the vacuum for the C/C. Also the wire leads all the way to the accelerator and it just pops off. Turn the plastic thing and unbolt the 2 10 millimieter screws and disconnect the plug/vacuum hose and pull out. Basically he covered the PS.
        ohh damn i though it was hard..thnx brothers..where is the cruise control anyway??
        MY 1n2 CB7
          People actually disconnect/throw away Cruise control and power steering?!?!?!
          WTH?....I pay xtra to HAVE these features on a car!! Maybe I'm just old now?
          '91 Honda Accord EX
          5-speed manual Tranny
          Stock
            i dont get it either?
            is the weight reduction asociated with removing the cruise control actuator that significant of a gain to throw away a nice feature? run your car at the track before and after and see if you gain. i bet not. i bet you got a sub in the trunk too!
            http://www.cb7tuner.com/vbb/showthread.php?t=22013
            cb7tuner.com Cleveland division
              I got an H22...the cruise control is basically useless in my car so i took it out. As for the PS im going to be taking that out after i find a place to help me make a coupler to loop the high and low side. Im taking out PS cuz its puttin a hump in my hood and its slowly starting to rust which is pissin me off.
                you dont have to just leave the cable in the engine bay tucked somewhere.... if you go on the floor in your car on the driver's side there's a cable attatched to your gas pedal for the cruise control you can just disconnect it then you can pull the cable through the fire wall from the engine compartment and simply unbolt and unplug the c/c.... then you can always put it back in later if you want (nothing is damaged this way)
                Collin
                  the only reason i ever got rid of my c/c is because it wasn't working in the first place not to mention i put on an aftermarket steering wheel.... otherwise i definately would have kept it.
                  Collin
