If putting the stock pressure plate back on didn't work, I don't see why putting the stock transmission back on would fix the problem unless there was a actual physical larger gap between the pressure plate and clutch fork on the new transmission. That 1" less of travel bothers me though and is probably most definitely not enough travel to engage the clutch. I do know that you said you put the spacer on for the master cylinder though so it should have given it the extra inch you are missing and if you are missing a whole inch i don't see what the 1/8" difference on the pressure plate would matter that much compared too the full inch, but in the meantime if your are putting the old transmission back on i thought that i should mention you probably want to remove the spacer you put on for the new transmission or your clutch might not engage/disengage properly with the stock one.
New Clutch not Disengaging. Took back Apart. Nothing looks Wrong??
Jeremy,
Thanks for replying. Ya know I really would hate to swap the stock trans back in and then I still can't get into gear, and it was the master or something else. I should do more trouble shooting now while I can. Yes I agree the 1 in of travel is still not right so I am actually starting to think this is something with the master and probably gonna go ahead and swap the old master to see if that changes something.
Yeah i would definitely try swapping the old master cylinder back on, that fork travel looks like it would barely be enough to maybe reach the pressure plate since the pivot point in the transmission is closer towards the shaft then the slave cylinder, when you move the slave pin out 1" it probably only moves the fork in the transmission MAYBE 3/4" towards the pressure plate. I believe that the old master cylinder gave it the extra inch it needed since you have said you have bled the new one multiple times with no success. Also i would check if the new and old master cylinders are the same size or if they hold different fluid amounts because that might affect it.
Ya, i think you should figure this out. These could be parts you'll want to use in the future.
Pushed in with my hand.
Pushed out via the pedal.
Probably doesn't move this much with the pressure of the trans on it but probably 1/2" of travel. I didn't move / adjust my clutch at all under the dash and this is my working setup. If you are getting the same travel as I am then the issue is your pressure plate or the release bearing. What's the measurement of your bearing? Mine is 1.11" but I shaved it down for the race clutch.
Originally posted by JeremyLDT View PostYeah i would definitely try swapping the old master cylinder back on, that fork travel looks like it would barely be enough to maybe reach the pressure plate since the pivot point in the transmission is closer towards the shaft then the slave cylinder, when you move the slave pin out 1" it probably only moves the fork in the transmission MAYBE 3/4" towards the pressure plate. I believe that the old master cylinder gave it the extra inch it needed since you have said you have bled the new one multiple times with no success. Also i would check if the new and old master cylinders are the same size or if they hold different fluid amounts because that might affect it.
I am curious on the throw out bearing. But at this point, I mean I would put back the old setup and see what happens, then slowly start putting new stuff back on, But that would be a pain in the butt.~Nick~
I am running the release bearing that came with the exedy clutch kit I bought. I have some pics of both and they do look the same style but I'll go ahead and pull the trans again to take a closer look and measure width. Thanks guys
New release bearing from Stage 1 exedy kit. On T2T4 trans
Old release bearing. unknown brand. On stock F trans
Ya, I'm not seeing much of a difference there. At this point it's safe to assume you have the wrong pressure plate or release bearing combo. It's the only measurement that's not right so far & the teeth on that plate are indeed too low. Just enough to not have the clutch fully release it seems. One would think if you were 1/8" from release that you could take that up with the pedal / rod adjustment, but seems not.
Have you reached out to Exedy about this yet?
