93 auto transmission shifting issue
    Accord with 367000 miles. Everything works as it should until transmission heats up. When I put it into reverse once warm then d4, the car will not move until I give it some gas. Once I'm underway the transmission shifts fine until I need to use the reverse. I changed the transmission fluid recently. The problem existed before I changed it. If I put it into neutral then D4 no problems, until I use reverse.
    Thanks.
    Never experienced this. But I would imagine its something wrong with the gear selector cable. Maybe its kinked. Sounds lots its not going fully into drive when youre expecting it to .
      thanks
        I found a work around. I'm guessing the transmission may be failing. I try d4 first if the car doesn't move I put it in first. The car gets underway than I put it into D4 and it works. I'll see how long it lasts. A year would be wonderful.
