Prepare for the wall of text, I know its long, I'm sorry. I'm also not the best at explaining things, I can rephrase something if you need me to.
I've been searching for a while with no luck. I got one of those free pdf service manuals, and I've been following instructions from that as well as cb7tuner, but now I'm just kind of confused as to what to do. Although, I think I've got it mostly squared down to it being a wiring issue. I paperclipped the switch on the thermostat housing, ig2 and the condenser fan only comes on. Swapped the radiator fan relay with the power window relay, didnt fix it. The relay wasnt even clicking, so, thats neat. From about this point, I followed the manual, and used a wired to jump the pins under the relay (2 & 4) radiator fan works, so all wiring from the fuse box to the fan, including the ground works, so thats good. However, when testing pins 1+ & 3- for battery voltage, it showed -0.21v on the multimeter. The manual says to repair the "Blu" wire, but isn't it the yellow that provides voltage? idrk how relays or any of this works. I saw some other singular page looking forum that said he repaired the blu wire, and had a pdf attached, showing the fusebox wires, c254 is supposedly the one I'm supposed to be looking at? I took the underhood fuse box out to inspect the wires underneath cuz it looked rather easy. They all looked fine close up, one had electrical tape wrapped around it loosely though it didnt look like it needed it. but, it wasnt the one in question, at least according to that one little pdf. All the insides of the connectors have disgusting gooey corrosion, making me wonder if I should just replace the wireharness, I've never had much luck cleaning that shit out. Besides, is the wire even my problem or is the fan timer unit? I have a 91 coupe ex manual. Also not sure if I'm looking at the proper wiring diagram, can I get help with all of this please.
From the manual:
path I took is in red.
From the manual:
