I have a '93 EX. I'm swapping in a JDM F22b1 after my original A6 ate an exhaust valve. In the first post of Swap FAQ: (Read Prior to Posting!) there is a blurb on switching from an external to internal coil dizzy. It says that the two large wires that used to go into the coil, yellow and yellow/black, need to be either spliced together or jumped with a fuse. Now , shouldn't those wires be going into the distributor instead? And yes, using the exterior coil dizzy might be easier but the B1 dizzy looks much cleaner.
Question about info in "Swap FAQ: (Read Prior to Posting!)"
