The down-low on ATF types
    Picking an ATF type for a 91 auto. Before someone flames me, yes, I have spent an hour inside the little search bar reading old posts.
    I know the original spec is Dexron II, something that's been dead since 1993.
    About 90% of posts here are religious fanatics about using Honda Z-1 ATF, which is long since discontinued, so that's what leads me back to here.
    I see plenty of people recommending to stick with the current Honda DW-1 ATF, but another half will immediately say it doesn't perform well in our older 4-speeds due to it's low viscosity. The more I read, the more confused I end up.
    Quite a few posts now recommend Valvoline MaxLife, a Dexron VI/MERCON-LV equivalent.
    From what I understand. DexVI is the last Dexron fluid designed to be backwards compatible with previous Dexrons (III and II mainly). so is the Valvoline (or other dexVI equivalent I can get my hands on) a good pick here? I'll probably just grab a jug and run a drain&fill this weekend regardless of responses to see how it feels, but personal ancedotes welcome!
    I ...... never thought it made a difference. I just use OEM. But this also depends on where you live too (hot or cold), just like engine oil.
      Maybe it doesn't. I'm used to overthinking fluid choices 'cause I come from the Subaru realm where using the slightly wrong type of gear oil will ruin your synchros lol, so I've learned to be paranoid. But I guess these old beater 4 speeds really don't care that much.
      F**k it, i'm throwing valvoline in there, my stupid dealer monopoly wants $19/qt for DW-1 and I'm not about that. Forget I even asked this question, will report back if something janky happens.
        I've been using Valvoline for years. I change it often. 381000 original auto trans.
          I take that as a good vote of confidence in Valvoline. Thanks!
          I just did the first drain&fill this morning, going to drive to town for an event, then do another drain and fill when I get home.
