Picking an ATF type for a 91 auto. Before someone flames me, yes, I have spent an hour inside the little search bar reading old posts.
I know the original spec is Dexron II, something that's been dead since 1993.
About 90% of posts here are religious fanatics about using Honda Z-1 ATF, which is long since discontinued, so that's what leads me back to here.
I see plenty of people recommending to stick with the current Honda DW-1 ATF, but another half will immediately say it doesn't perform well in our older 4-speeds due to it's low viscosity. The more I read, the more confused I end up.
Quite a few posts now recommend Valvoline MaxLife, a Dexron VI/MERCON-LV equivalent.
From what I understand. DexVI is the last Dexron fluid designed to be backwards compatible with previous Dexrons (III and II mainly). so is the Valvoline (or other dexVI equivalent I can get my hands on) a good pick here? I'll probably just grab a jug and run a drain&fill this weekend regardless of responses to see how it feels, but personal ancedotes welcome!
