Hey guys, long time lurker and first time posting so bear with me.
1991 LX auto but gathering manual swap parts, with F22A1 and the following-
ALL the A6 parts.
68mm TB
I/H/E
Balance shaft delete
light porting on TB, Intake manifold and head
Dual core radiator with new fans and shroud.
Complete teardown and overhaul (main and Rod bearings, pistons and rings, all new seals on everything, water pump, oil pump, timing belt kit, distributor rebuild, oil catch can)
I had to have the head milled 0.020 (damaged by prior owner) this will put me about 9.2:1 if the calculator is correct.
I am starting the build back this weekend and am wondering if I will need a tune with the porting and now the bump in compression?
My goal is just a solid build with healthy power and not to be trying to run down little timmy on the street.
But I do drive what I build and don't shy away from playing well with others. This will be my daily fun driver.
Will the PT6 support the mods well enough for a fun daily until I can decide what ECU to run?
Thoughts on ECU and tune if needed or for future?
Any issues with this build I may be missing?
The only other thing I need to find better info on is the wiring for the IAB, I know there was a post for this info I just need to find it again.
Thanks in advance for the help!
ALL the A6 parts.
68mm TB
I/H/E
