when doing this swap, #1 advice is to pull the motor out to doit, it makes your life easier! Trust me!
Auto to 5 speed swap wiring questions!
This topic is closed.
yea it might be easier to do the swap while the motor is out but i dont have all the tools to do that
CLICK ON SIG FOR MEMBERS RIDE
"2SIIC"
Authentic Jerseys for sale
http://www.cb7tuner.com/vbb/showthread.php?t=188314
"2SIIC"
dude, just rent an engine hoist. You will need one to do the swap.
For the other Q about the second *box* the ecu doesn't matter auto or standard, the second computer is the TCU controller and won't be on standard cars in the first place. Btw remove the tcu when you do a 5sp swap. Hopin to do mine soon as well.
Originally posted by Smokinspeedsdude, just rent an engine hoist. You will need one to do the swap.
yea ill rent one when i do the h22 swap but for the tranny swap all i need is to floor jacks
hey so your saying we can still use the ecu we have and just take out the TCU next to it
"2SIIC"
oh alright i thought that you had to get a MT ecu because if you use the auto ECU it will run like shit
"2SIIC"
if it dont work and you get a code, it might be a flash 30 and 31, wich i believe are the 2 shift solenoids onthe transmission. But i also believe, if you got the computer wire in for the park or neutral mode, then that should not go about throwing the cel, Ok, but if it does, then you dont have the car in park or neutral!
Originally posted by Davids92Accordoh alright i thought that you had to get a MT ecu because if you use the auto ECU it will run like shit
well the only reason i thought that we needed another ecu was because its on the 5 speed swap list and i was just following the instructions so i guess i was wrong but theanks for pointing that out man
"2SIIC"
AT and MT ECUs did in fact differ, not sure of the effects of the differences but one i know is that the AT ecu will keep the radiator fans running up to 15 minutes after the car is off, an MT wont. converting an AT ECU to MT is as easy as pulling out a couple transistors, but for details youll have to look it up. either ECU will work with either tranny, but of course for an AT youll need the TCU as well.
