heat not working
    heat not working
    my heats not workin on my car, any1 no soemthings i can check to see why its not working>?
    Check your coolant level, and please search. There are 2 more threads floating around with the same question.
      check you coolant, is your thermostat opening, or is it stuck open, does your car overheat, need more info
      New cb, new start
        car does not over heat, idk where the thermostat is located, could my heating coil be bad? if so where is it located?
          you dont have a heating coil, you have a heater core, but you have to pull the dash to replace it, and your thermostat is in your upper radiator hose housing, usualy 2 bolts and a gasket, cost about 10bucks at autozone, might be worth a shot. i would start at the thermastat and go from there, start at the cheapest thing than work twards your dash being pulled out
          New cb, new start
            alright thanx man, i hope its that, is that a problem alot of the time when peoples heat doesnt work??
              What does your temp guage say? If it is climbing really high, then it probably is a thermostat. If your temp is normal, but no heat, you may have to play with the heater core.
              I have seen situation where people didn't change their coolant enough and it caused the heater core to get blocked up. One way to try to check for this is to thoroughly flush your system. Here are some steps to do it:
              1) Drain your coolant (be careful with the old coolant as it is not good for the environment and cats and dogs do like to drink it... and die...)
              2) Fill your radiator back up with plain water.
              3) Start the car and let it run for about ten minutes.
              4) Shut it off and drain it again.
              Do this until the water starts coming out clear. I think you can also get to the hoses for the heater core from the engine bay. You can try to clean from there as well. It is a real pain in the ass to clean a heater core if it is clogged. It will work for a bit and then get clogged again as some other gunk gets lodged.
              -c
                the temp goes half way then stops there and doesnt climb, so sounds like ill b draining my system, where do i drain it from? and yes i no these r stupid ?'s
                  you can flush the system by opening the plug on the bottom center of your radiator, righty tighty lefty loosey as always and make sure you have somthing to hold all the coolant, i think its 4 gallons total with watter, but dont quote me.
                  yeah if the heater core is even partialy clogged its prolly better to change it out, the openings inside of it are usualy so small that its more of a headache to clean it than to change it, i pulled my dash b4 i put my car in the garage, and its only 9 bolts and a few wire harnesses. just be carefull and remember where the harnesses go because behind you dash you might as well get some sauce for all that spagetti
                  New cb, new start
                    whats the quickest way 2 get 2 the heater core? and is it exspensive to buy a new 1?
                      i work until 7 on friday, i can hear the knob turnign to heat, its just not blowing hot air, only cold, but if u got a diff soultion im down, i usually go 2 my friends house after ig et off and he lives on switzer, he is the 1 witht he prelude that isnt running, u can coem over there and look at it if u want 2??
                        see thats what i thought when i replaced my thermostat but i got the upper off and to my surprise no thermo.... it was on the lower line ..... its a its a 90 lx accord
                        btw what does cb7 stand for i've read/heard like 10 dif. explnations
                        R.I.P. 6-10-07
                        (\__/)
                        (O.o )
                        My Rotor DIY
                        I'm not perfect i will make mistakes if i do just point it out to me
