Egr
    Egr
    when you put a block of plate at the egr mounting point what do you do with the vac line and pig tail plug to the egr valve ....just until i get a new
    one igot a code 12 for the egr thanx
    Depending on how thick your plate is you could just put the EGR on top of it and hook it back up. if the plate is to thick and the egr wont bolt up just plug the vaccum line and leave the pig tail alone. youll get a code but it wont affect drivig or anithing.
      You need to leave both vacuum and the plug connected. It senses for movement of the valve. If you leave it connected usually it wont throw a CEL. Some people use the lile coke cans and such and cut the shape out. They put like 3-4 layers stack them together and throw the valve on. and bolt it back down.
        Where-ever you put the valve (over your plate, or just hanging down/ziptied out of sight) keep the vac. line and plug connected. The ECU won't know the difference.
          just put the valve on the plate and hook up everything back to stock.
          if you got something smart to say, guess what, i dont care.
            damn guyz thanx alot i was wondering...... hey nail05 if i hook the valve back up it wont throw any codes even though its say the valve is bad to begin with .....just wondering......
              If the valve is bad it will throw a code. The sensor just sense the movement of the valve and if it doesnt detect it moving it will throw a code and such. But if your doing a block off plate just clean the EGR put the plate in between put EGR back on and then hook everything up. Thats how most people do it anyway.
