is there a such thing as a fly wheel that is too light?
    I got the ACT 8 or 9lb flywheel and I was told by a friend it may be too light and that I should have gotten a 12 or 13 lb......
    what will be the difference in performance?
    Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
    ...Zex wet kit, 65 shot, dual purge, JDM H22...pure sex! .....I owned 8 CB7's in one year...top that JARHEAD...lol
    ...this thread has been graced by the new CB7 King
    lighter flywheel = faster revving, but lighter flywheel has less mass therefore less inertia, so if its really light you may have to have the idle speed adjusted a little higher so there is enough energy to keep it spinning
    Click here to see my ride!
      good answer. i had the same question ahah
      vanillagorilla A.k.A glock22
      Then one day I meet a man,
      He came to me and said,
      "Hard work good and hard work fine,
      but first take care of head"
        It will downrev just as quick so if you slack off it will bite you. Personally I would prefer a 12lb for dd. IF I was needing a track car thats when an 8-9lb is needed.
          yeah i always wondered why so many people i meet rave about them. i heard a similar type of argument about putting a h22 trans in a accord. shorter gears vs. longer gears. turnout ended up being longer gears so you stay in boost longer
            I've driven an Accord with an 8 pound flywheel. It's fun if you're going for it on twisty roads and need to up and downshift a lot. However, having to downshift to 2nd or 3rd to go up hills is a little tedious.
            I think I'd stick to an 11 or 12 lb unit for the streets, especially if it was a daily driver.
            If it was a weekend only or part time track car, I'd rock an 8 or 9 lb piece.
              i am a bit curious though to as how it would work out with a trans with longer gears and a lightened flywheel
                I have a 12lb now... not really that much different from stock, honestly. 2 days to get used to it, and it was fine. I'll probably go for a lighter one soon.
                Too light and you will have problems, yes. When you shift and let off the gas, the RPMs will drop much faster the lighter you go. Too much of that is bad. A little is good, if you can shift quickly!
                  You just got used to it thats all =P.
                    It wasn't that big a change in the first place (don't let cp[mike], MRX, AccordWarrior, or prodigymb tell you any different!)
                      I think on a motor that has a decent amount of torque to begin w/ a light flywheel, like 8 or 9 lbs would be okay. On a motor w/ little torque to begin w/, you're going to have to rev it much higher just to get an effective amount of torque. I myself am planning on an 8 or 9 lb flywheel once I put my M2B4 on my F22a6. And in reference to shorter gears and boost, longer gears help only when traction is a problem w/ shorter gears, but otherwise, it'll still be the same benefits as N/A.
                        I just ordered a 8lb fidanza.
                          im running a 9 pounder with short gearing, and i <3 every second of it.
                            And your car was the one I was referencing of why I wouldn't get an 8 lb flywheel on a street car.
                              mines 7.5 and it feels OEM except when i RUn it and the clutch feels funny afterwards
                              either kill it or drift it...
                              2002 Toyota Tundra V8
