Originally posted by PakaloloHonda
How to make 30+hp for $500 or less... (DX/LX F22A1 only)
This topic is closed.
This is a sticky topic.
Originally posted by owequititThat is indeed an A6 upper half. You can leave the heatshield off, but it will raise your underhood temps by quite a bit.
and ceramic coated .. about as much .. or more?
I'm just trying to find out by how much more the underhood temps could be.
Would the a1 shield fit? (I dont believe it would) just looking at it, it looks like .. no, lol.
A Hui Hou !!!
TomiLast edited by PakaloloHonda; 01-06-2008, 09:30 AM.
Originally posted by PakaloloHondaIn terms of quite a bit ... compared to a DC Sports header (which is steel)
A Hui Hou !!!
Tomi
I never measured exactly, but it is definitely noticeable.
I would say about the same as a SS DC header, and more than a ceramic one.
so if i where to create "in other words" an a6
a6 intake, cam, and ecu would do,
what about the rocker arm assembly, does it even change?
what bout the springs, are the a6 stiffer (dont assume plis)
i
f u get an 150k miles cam, and throw it an a 100k mile head,
wouldnt bearing clearences on the cam be affected?
header would be an a4
and YES PEOPLE the IAB's
would that be it ?
The P12 may not provide the same gains with the A6 camshaft.
The A6 valvesprings are a different part number than the A1 and A4. Because the camshaft is a wilder profile, it only makes sense that they are stiffer springs.
The A6 also has a windage tray (not listed in the initial parts list)
The A4 header may not be a full 5hp over the A6 cast manifold, due to the similar design. The tubular design of the A4 manifold is technically superior to the cast A6 piece, but the potential gain is unknown.
As for a 150k mile cam... that's 150,000 miles of friction on that metal stick. They do wear.
Originally posted by deevergoteI didn't say that at all.
and u'll probably have different bearing clearences, same with a cam,
it aint gonna stop me from throwing the cam, but if u think bout it
some people will not,
cuz they think everything is bolt on, they'll assume, EVERYTHING IS...
BOLT ON,
A6 does have different intake and exhaust valve springs than the A1/A4 motor. Interesting how the more we dig into these differences, the more we find.
Here are some color designations to tell the differences between springs physically:
A6
INT - blue
EXH - green
A1/A4
INT - yellow
EXH - orange
