Windshield Fluid Nozzles
    Is it just me or do our windshield washer fluid nozzles suck ass?
    Just curious, three out of four of my squirters (not sure of the exact technical specification) don't really squirt anything out of them. Is there anything you guys have done to make them work when they get clogged?
    I was thinking of retrofitting some recent model Camry nozzles onto the Accord tubes because my dad's Camry has these awesome wide dispersion nozzles that are way better than the directional ones on the Accord. Still, I think the inherent lousiness of the fluid delivery also has something to do with the age and level of wear on the fluid reservoir pump as well.
    Any suggestions or things you've all done to improve our fluid delivery sytems?
    1992 Accord LX Wagon 248K/155 Miles
    Mine spray too much they go over the car
    wat?
      Well thats easy enough to fix, you just use a small pointy thing (i.e. sewing needle) and adjust the nozzle head til it aims at the windshield
        mine were great until I changed my hood I am going to change all my plumbing
        and see if that helps
        WE MISS YOU JO(9-04-2008)
          I just bought new nozzles. They cost like $7 for a pair at the Honda dealership.
            i fixed mine jus yesterday, i went ahead and replaced the old pump and i unhooked the hose from the pump and nozzles and blew air thru it. managed to blow all the gunk out of the system, and one of the hoses from inside the fender so i had to take the fender lining apart to put the hose back on.
            to fix the nozzles i just blew brake parts cleaner thru the inside. and it cleared up the remainder of the gunk inside. put everything back and sure enough they squirted out fine.
            (129)Transactions and counting
              when you say they worked fine do you mean they were about the same as before, or like way way better than they ever were?
              If the pump is not that good to begin with, I'm going to think about finding a newer car's pump that I could fit in there. New cars seem to have a much more effective system overall
                That's so weird, I threw a couple of different words relating to this query in the search tool and nothing recent came up. And now a thread's popping up in the Beginner Appearance section thats all about this and has been active for the last few days.
                Oh well, two threads possibly means more responses....lol
                  http://www.cb7tuner.com/vbb/showthread.php?t=91384
                  I imagine if you TRULY wanna fix the problem, you have to pull apart the fenders, and replacing/clean ever piece of hosing and check the motor and everything.
                  Im in the process of seeing if replacing the hosing will work, but ive got a feeling theres more to it than that.....
                  Originally posted by Jarrett
                    A nice upgrade, if you will, would be the nozzles from the 6th gen Accords (98-02), the nozzle has a single outlet but fans it out instead of a stream/jet. They cannot be adjusted, but that's not really an issue unless you have done the hood stand off mod that's over 2" . The CB nozzles seem to do a really great job if they are clear and adjusted properly.
                    Also, I might add, the 6th gen ones have the inlet/nipple pointing towards the front of the car and not towards the d/s fender.
                      yes they do suck and so does the motor.
                      ...adjust accordingly
                        Is anyone else hearing an echo......
                          1. If its clogged it wont spray
                          2. Get a little needle and jam it in.
                          3. Pull rubber hoses for inspection.
                          4. If the pump is not working it wont work as effective.
                          5. A needle that can fit in the nozzle will allow you to adjust it.
                          6. Mine dont work too well because I have wax clogging the holes I need to fix that with a needle.
                            Get ford nozzles... the only thing ford ever made that was good, their washer nozzles.. They spray everywhere, instead of one or two places...
                            90 Accord EX F22a1 Auto R.I.P.
                            2011 Mazda 3 Hatch 2.5L GS sport HELLO!
                              the left sideof mine sprayover the top of my car, anyway to adjust it?
                              93 accord lx
