Good Evening,
I recently had switched out my vacuum cruise control for a RSX electric cruise control. Below is some photos of my RA Odyssey cruise control swap, no different than the CB. You may have to fabricate the RSX electric cruise control actuator in the engine bay. I took a old CB cruise control brain/module and removed the connector so I could use the stock harness in the RA or CB. Below is a pinout I typed up for the actuator harness and brain/module harness, along with pictures.
Cruise Control Parts:
Module - 36700-s6m-a11
Actuator - 030100-1330
If you need help, comment below or you can reach me on the CB7 Discord: ----> https://www.cb7tuner.com/vbb5/forum/...ord#post215403
If you look at the pinout below it goes RSX/Accord pinout first then to Odyssey pinout.
Example BLU - (to) GRY = BRAKE INPUT (Description)
Cruise Control Vacuum to Electric Actuator/Brain
Actuator Pinout
RSX/Accord - Ody = Description
1 BLK - 1 BLK = GROUND
2 BRN/WHT - 3 BRN = VACUUM SOLENOID
3 BRN/YEL - 2 BRN/BLK = VENT SOLENOID
4 BRN - 4 BRN/WHT = SAFETY SOLENOID
Brain Pinout
1 BRN/WHT - 1 BRN/WHT = ACTUATOR CTRL
2 BLU - 2 GRY = BRAKE INPUT
3 BLK - 3 BLK = GROUND
4 BLK/ORN - 13 LT GRN = (shared) POWER INPUT
5 WHT/BLK - 4 GRN/WHT = BRAKE INPUT
6 GRY/RED - 5 LT GRN/RED = SET/DECEL INPUT
7 LT GRN/BLK - 6 LT GRN/BLK = RESUME/ACCEL INPUT
8 BLU/ORN - 7 BLU = RPM INPUT
9 BRN - 8 BRN = ACTUATOR CTRL
10 BLU/YEL - 9 RED = CRUISE CTRL IND
11 BRN/YEL - 10 BRN/BLK = ACTUATOR CTRL
12 BLU/WHT - 12 ORN = SPEED SENS INPUT
13 LT GRN - 13 LT GRN = (shared) POWER INPUT
14 LT BLU - 14 PNK = DISENGAGE INPUT
Without Colors
Brain Pinout
Actuator Pinout
Brain Pinout
Without Colors
Brain Pinout
