Hi. Installed bigger front rotors from prelude 2,2 and soon will install rotors on the back. You guys recommend 40-40 prop valve from Integra, but in Poland it will be hard to find. So I'm going to buy prop valve from cb9 (wagon). It also has bigger rotors front (like prelude) and rotors on the back. So I suppose it will be fine. But my question is what adventages integra valve has in comparision to cb9 that you guys recomend it ?
prop valve question
You'll be fine with a wagon prop valve. Don't worry about it!'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
I think it's pretty neat that you have access to a wagon with 4 wheel disk brakes + non ABS, here in the states any CB/CD/most other hondas that have 4 wheel disk brakes would automatically be ABS equipped. Some, not all, non ABS 90-01 Integras had disk brakes in the rear which broke that rule. I guess just make extra sure the wagon does not have ABS and be sure to post up what #'s are stamped into the valve (4040, 4030 etc)
Originally posted by Granite CB7 View PostI think it's pretty neat that you have access to a wagon with 4 wheel disk brakes + non ABS, here in the states any CB/CD/most other hondas that have 4 wheel disk brakes would automatically be ABS equipped. Some, not all, non ABS 90-01 Integras had disk brakes in the rear which broke that rule. I guess just make extra sure the wagon does not have ABS and be sure to post up what #'s are stamped into the valve (4040, 4030 etc)'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
With ABS there is no need for a prop valve. Prop valve is used to balance the brakes to maximize brake force. With ABS braking is given to all 4 corners and when one slips the computer intervenes. In our car the connection under the master cylinder looks like a prop valve, but there isn't any actual valving.'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
