i got my h23 head going on next week so i was just gonna go ahead and pull the power steering so i'd get used to not having it... but i can't really figure out how to either get the belt off.... or just pull the whole pump and plug the lines or pull the lines.... and i can't find a how to or anything about it.... if anybody knows plz let me know
anybody got a how to on removing power steering?
::disclaimer - im not responsible for any damage you may due to your car::
alright now to remove the whole power steering assembly do this..
1. disconnect all the fluid hoses at the pump
2. remove the bolt and nut on the adjustment assembly, the bolt your removing is on the right(drivers side)
3. remove the pivot bolt
4. remove the pump
**to remove just the belt just adjust the tensioner bolt**
try that and if you get stuck i might have enough time to take pictures
You may want to experiment first! You can do this by just taking the belt off and nothing else. The pump itself swings up and down for belt tensioning purposes. So, look underneath the pump itself, and you'll see the tensioner that pushes the pump up to set the belt tension. Loosen the tensioner, and then loosen 1 nut at the top and 1 nut at the bottom. Those hold the pump in position after the tension is set. It's hard to describe, but just look, and picture how the pump swings up and down to set the tension. You'll get it, good luck.
Dan
i need a manual.... i know... i'm broke tho
umm... i just took off the belt for the time being.... i drove it around the block...... and i really like it... i've driven a couple of cars without ps and its not that bad.... plus it seemed to free up my engine a little bit.... i need to get rid of the ac next...... but that's for some otehr weekend.... the ac chokes out my car all the time...
SOLD!
