I replaced my stock f22a6 with a JDM f22a due to rod knock. The swap went fine until I tried firing up the motor. There is fuel and the pressure is good, but it seems as though the injectors aren't opening. I can spray starting fluid down the throttle body and it runs so I for sure have spark. I have checked the injector resistor box and it shows 6ohms on all four.
There was a post about measuring voltage at the injectors and I found nothing. Im curious... do the injectors have constant power supplied and the ECM connect the circuit to ground when powered or are the injectors grounded and the ECM supplying 12v?
I have checked all fuses and everythings good. Is there an injector driver that went out or what?
