I know there's stroked H22's (2point6), but has anyone done a big dirty sohc?
Anyone stroked an f22a?
You stroke it the same way as the h22. You can either call crower and order there h22 stroker kit or do it the cheaper way and just find a h23 crank with your choice of pistons and rods. Just remember to order h23 pistons and rods.Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
I'm confused. The tech thread says the storke is the same between the h23a1 and f22a; the h23 just has a bigger bore. Cause i have an h23a1 kickin around so that would be really convenient.Last edited by psyphre; 06-11-2006, 11:35 PM.
i don't even think the pistons would fit at all, f22a bore is 85mm, h23 is 87mm.
EDIT: i looked at the crower stroker kits, or should i say the crower "bore the hell out of the motor" stroker kits.Last edited by psyphre; 06-12-2006, 08:35 AM.
Originally posted by psyphreI'm confused. The tech thread says the storke is the same between the h23a1 and f22a; the h23 just has a bigger bore. Cause i have an h23a1 kickin around so that would be really convenient.Oil leak?What oil leak? That's just sweat from all that horsepower!
STROKE
H22A = 90.7mm/3.570
H22A1 = 90.7mm/3.570
H22A4 = 90.7mm/3.570
H23A = 95mm/3.740
H23A1 = 95mm/3.740
F20A = 88mm/3.464
F20B = 88mm/3.464
F22A = 95mm/3.740
F22B = 95mm/3.740
F22B1 = 95mm/3.740
F22B2 = 95mm/3.740
F23A = 97mm/3.818
Taken from the sticky at the top of this forum.
But he's not trying to stroke a h22, he's trying to stroke a f22.Shift_BOOST
BOOM!
The F22a and H23 crank are identical part #s from honda... I believe the F23 crank will not work due to a different journal size. Our motors have a huge stroke already... if you sleeve it you can bore to 92mm i believe, on a n/a setup and i think 89 or 90mm on a boosted setup(according to darton)12.5 at 114.6mph 15psi
11.7 and 11.5 20.5psi
F22a1
60-1 td06h turbo
Darton mid sleeves
85.5 wiseco 8.8:1 forged pistons
Crower pro billet rods
Custom ported head.
KMS valves
F23 headgasket
ARP H23 headstuds
H23 upper intake manifold
F22a6 lower intake manifold
Intake manifold is gutted
AEM EMS 1040u
FIC 850cc injectors
Walbro 255 pump
H23 manual trans
Prelude shifter assembly
Forbidden short throw
Nitrous Express Kit installed, never used on this motor
