i got my moates burn1, and my chipped ecu, first it started right up in limp mode and wouldnt rev past 3k, then after reburning and messin with it for hours it finally started and ran good using d112crzy's f22 base map, it ran good all night with the FTL and everything, then today i tried to reburn it and lower the FTL, and now it wont start i reburned it a billion times and reinstalled the software, and the chip is in the right way in the burner and the ecu and it says it burns successfully HOW DO I MAKE IT RUN AGAIN!! the stock ecu is back in until i get some help
tuning is bummin me out
I had the same sort of problem with mine. Couldn't get it to run for more than a day or two before it would go into limp mode using any of the 1.7's. Downloaded Uber v1.66, reburned the chip and it ran fine (until the ringlands went, but that's a different story)1993 Prelude S
F22A1
custom'ish turbo setup
180 whp/217 ft-lbs super hot, super humid, super rich, boost falling off at 8psi
18psi boost spike = BOOM!!!!!
currently being rebuilt
Originally posted by spitfireskatr7i dont know if me wiggling the j1 jumper had anything to do it, or that i redownloaded the map and burned it unmolested, does it do anything if the map was made on a different version of uber cuz i think the map is from 1.7repact1review1 and i have 1.7repact1review2.2
wiggling j1? is it not attached or somting if not then ofcourse that is most likely the reason why its not working. and yes it does matter what version of uber u run certain maps on. also if u are running different upgrades or certain files created for uber patched into 1.7 it can screw with the maps and chage values. if u can A0l Aim me and send me the maps u have and i can see if at least the maps all look good under uber 1.7. good luk man.
