will the pros and cons of a light flywheel cancel each other out on a 1/4 track?
    since a lighter flywheel hurts your launch, and it will help you accelerate fast, wont they cancel each other out?
    like for example, you launch, but it's really slow...
    then a few seconds later, you speed up and shift through the gears really FAST
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    lighter is better i would say unless you got some mad power to keep a heavy fly wheel
      they don't make a lot of difference to start with.
        nope not at all the main key is to help you get off the line quicker and get to your powerband quicker and keep it that way.
          On my red Accord project, stock flywheel weighed 17 lbs. I have a 12 lb. flywheel installed in it and you notice it revs easier, but the drop of the rpms is not bad at all. I would say 12 lb. flywheel is a great balance for a daily driver that wants some performance. I have a 8.5 lb flywheel going into my white project Accord, I can not attest to that yet until it's driveable. I assume it to be more noticeable of a rpm drop when off the gas.
          EDIT: The 8.5lb flywheel on white Accord is noticeably lighter than my red Accord 12 lb, however is still driveable. It's all in getting use to taking off from a stop, you have to coordinate your gas pedal/clutch pedal movements better. Once you get used to that, it is golden.
            the zc came with a diaphragm that holds the throttle for 1 second between shifts. it's an easy fix for someone with dropping rpm worries.
            it does drop more between shifts, but requires less power to get back to full speed
              Having driven an 8lb flywheel, 12lb flywheel, and a stock flywheel at the drag strip, the 8lb one is near impossible to launch perfectly, and it's very unstreetable. The stock one is great on the street, easy to launch with, but slow to drop down to the right rpm for quick shifts making it a little jerky. The 12 pounder is a great compromise. There is a 12lb on in my prelude right now, and I love it. Super easy to get used to. Im going to stick with it.
                hmm, im trying to decide betwen a 9.9 and a 12
                MY CB7
                  there are no cons with a 12 pounder.
                  one thing i cant figure out is when i hit the clutch to take it out of gear, my revs kinda shoot up a bit and begin dropping.
                    Your foots still on the gas.
                      correct, take your foot off the gas faster.
                      p.s. i tap the gas a tiny bit when i hit the clutch, too. i got used to the right force to give it so the RPMs shoot up a tad, and fall right in place at the exact time im in the next gear, ready to let go of the clutch...
                      im running a 9lb, daily, street, and love it... no complaints whatsoever... just wimpy launches sometimes if you try to just rev up and drop the clutch. its like UGHH cuz it feels like it just putzes out and doesnt accelerate. but still very easy to overcome by revving & slipping more! with a lighter flywheel you have to finess and play with the clutch more accurately to overcome the "cons" ... still, just something to get used to, i dont consider it a con at all
                        I feel the same way about my 8lb.
                        To-Do List for Today
                        Be Awesome
                          I have a 7lbs flywheel and its great for daily use it feels like OEM but better Acceleration. i don't need to rev any higher to go anywhere. but there is a downfall if your @ a stop and its a steep hill then you would need to rev a bit higher to move the car. but in all 7 lbs is for race application but its a good buy.
                          either kill it or drift it...
                          2002 Toyota Tundra V8
                            I have a 10lb XTD flywheel and love it.. the notice was night and day.. but like others have said normal driving take off is a little different.. But to me the only reason to have a lightened flywheel is to smash out those down shifts.. you can flick the RPMs up no problem..
                            oh also my mechanic warned me about this and it does happen some time. I get some vibrations from my flywheel.. you can hear it but besides that never had a problem.
                              Yeah I cant get up hills on campus in 5th anymore.. Oh well.
                              Be Awesome
