Are any of you familiar with tuning a Hondata S300? I just got one that was already installed in a P28 and I installed it in my car, loaded the Prelude map that came with the software, and made a few tweaks (mainly VTEC engagement, IAB control, disable knock sensor (to get rid of the MIL), and other minor things). First off, the ignition tables in that map are no good for my car... Also, it seems to run a bit richer and I'm getting knock all over the RPM range (reading knock from the sensor with a S-AFC). Attempted to tune the ignition map and got it to where it was driveable, then when VTEC hit in 3rd gear (yes, only in 3rd gear) the car sputtered BADLY. Backed off the throttle and drove the rest of the way to work. Then came home after work and loaded the P72 basemap, upped the injector size and it ran a lot better. Removed some of the timing and it was even better, but I'm still reading knock from the sensor.
Long story short, if any of you are familiar with this setup, I would appreciate it if you could send me a map that would get me going in the right direction. I'm going to get it dyno tuned soon, but funds say that I have to wait a few weeks at least.
Oh, in case you don't know, I'm running a mostly stock H22A1 with the M2F4 trans, Greddy header with 2 1/4 exhaust and an AEM CAI.
Thanks!
Thanks!
