chipped ecu and AFC??
    can you run a chipped p06 and an AFC at the same time or will that mess with shit??
    HAN - ZiviCase10287
    Honda-tech - zivicase
    HMT - draztik
    d-series - draztik
    Team Integra - RacinMasonC
    You can but I really dont see much use of the AFC after a chipped ECU. Unless you just use it for minor correction.
      yes and to monitor other things on the AFC.. i didn't know if it would make the ecu go crazy or what not
      HAN - ZiviCase10287
      HMT - draztik
      d-series - draztik
        there is absolutely no need for an afc if you have an ecu.
        if you want to monitor things, get gauges or get a laptop to datalog.
          well when your factory tac is off.. and your idle is going crazy its kinda hard to adjust isn't it? took me 6 months to finally figure out the stock tac is off till redline.. at 500-1000rpms it still says 500rpms.. at 2700 actual rpms the stock tac reads a lil over 3000rpms... don't feel like carrying a laptop in my car at all times.
          HAN - ZiviCase10287
          HMT - draztik
          d-series - draztik
            You should fix those things before worrying about performance.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              rofl.. fix what? cuz the stock tac is going to blow up my engine.. the needle will bounce everywhere when its not actually doing it.. thats why i put the afc in there to see if the tac is just fucked up.. it reads correctly after 5500rpms.. thats all i care about. put your laptop in a freezer!!! thats what its like here in MN if i left a laptop in my car.
              HAN - ZiviCase10287
              HMT - draztik
              d-series - draztik
                get an aftermarket tac then.
                but if all you're gona use the afc for is your tac then its all gravy.
                  ok heres a question, if i have an FMU rigged into my car to control boost on a supercharger can i still chip, or would the FMU be pointless after a chip or just fuck things up...
                    Dependin on who installed it properly and if its tuned properly. Youll just complicate things more ,then in the end just straight up fuck shit up. Just stick with the standalone get it tuned 1 good time and call it a day.
                      the afc will be used to see what my rpms actually are, if and idle problem accurs, vacuum.. and throttle % thats about all.. and minor correction if i need it.
                      but i don't need anymore gauges, i have volts, oil pressure, a/f, water temp
                      HAN - ZiviCase10287
                      HMT - draztik
                      d-series - draztik
                        Its alot safer to read a tach than to look at an SAFC to shift IMO. Personally i'd fix the tach, end up saving you like $150-200 off the cost of the AFC anyways.
                          I have a VAFC =D. I dont depend on it to shift though. I just use it to measure my peak readings thats it after a run or so. Other than that it just sits there. Plus I got it for free so yea.
                            u could also add a shift light with the ecu. I guess i'm more concerned about the racing aspects of not having a tach
                              Wow man... I got mine for free to just never hooked it up.... What would a + be for have'n one.... I mean do you get an ajustable power band or something?
                              My Members Ride Thread ( Do It )
