Turbo power ratings sorted by engine type
ill always say.. 3" exhaust. and some bigger injectors.. and that car would of been capable of close to 300wheel..
it sadly got a spun bearing.. after about a year of torture.. but hey.. 220k block.. lol.. so meh.. it did its job
Leave a comment:
Twokex im right there with you..although a slipping clutch prevented me from doing the 15psi pull that I wanted. So we had to backdown to 10psi
Setup:
1992 ex 4dr frost white
210k engine
Ebay turbo kit
Log manifold
T3/t4 63ar
Large fmic
Hks ssqv knock
Dsm 450cc
2.5"DP
2.25 exhaust
S2k muffler(restriction)
Basemapped/partial street tune
No dynotune was possible the turbine seals have gone bad on the turbo..the smoke causes my wideband readings 2 be off(well the shops wideband anyway) mine is down right now. not too shabby considering at first we didn't have an oil restrictor
So basiclly this map was compiled from previous f22a maps I've done and the use of a det can..no wideband was used (yet) more power left IMO..if it would hold 15psi (does fine on the street though lol)
Dynoplot was done at such a high rpm due to fear of slipping..and even at 10psi u can see the graph towards redline become wavey(signs of slipping)
New turbo..wideband tune...15psi..I promise 300wheel..on this beater block..hehe
F22a6
250whp
246wtq
10psiLast edited by WiKKeDV16; 12-20-2008, 12:13 PM.
Leave a comment:
i doubt chassis matters.
(if it doesn't) F22a1, T3super60 @ 10psi: 250hp/275lb-ft
Leave a comment:
Originally posted by chessboxer View PostI posted this in an old thread, but here is the breakdown of the most powerful turbo motors by motor type. I've tried to include psi, turbo size, and power levels.
F22A
Straightedge - 402whp / 325wtq Holset@ 20psi F22a
Turbo90accord - 315 whp/ 297 wtq T3/T04 60-1@14.5psi F22a SOHC
Dep22build - 300 whp/315 wtq t3/t4 hybrid@16psi F22a1/h23 head
Chessboxer - 244whp/239wtq 14b@12 psi f22a1
quickangel93- 243whp/235wtq 14b@12psi f22a6/a1
youngJAY - 201whp/212wtrq 14b@ 8 psi f22a6
Quaidum-198whp/207wtq f22a6 sohc 13c turbo
91accordexr33 - 188whp/188wtq F22a4 sohc 16g@8psi auto trans
Mullet - 179whp/217wtq @10psi F22a SOHC
F22B DOHC
CBL - 313 whp/298 wtq GT32@14psi F22B DOHC
hurricanedsm - 270whp, F22B DOHC, turbonetics 54 trim 10-12psi
gdout90accord - 247whp/246 tq@9psi t3t4 F22B DOHC
92ex - 194whp/205wtq 14b@8psi F22B DOHC
F22B SOHC
91accordexR33 - 307 whp/298wtq GT30R@20psi F22b1 SOHC
4doorkiller - 230whp/245wtq t3/t4OB@ 10psi JDM F22B SOHC VTEC
H22
Accord_SIR - 414 whp/ 334wtq SC61@???psi H22
Mozzandherb - 248whp/190 wtq t3/t04e@8psi H22a
H23
93sleeper 504 hp/437 tq t3/t4@ 20 psi H23 DOHC
bjaccord - 280whp/258wtq t3/t04e@9.5psi h23 DOHC
oneoffaccord - 241whp/243wtq t3/t04e@ 8psi H23 DOHC
G22/G23
LoDollar92LX - 526 whp/ 400 wtq T3/T04R@18psi G22vtec
Turboh22accord - 292 whp/238 wtq t3/t70@12psi G23vtec
F20
Alex EX - 194whp/198wtq 14b@7psi F20A DOHC
MidnightRayne - 174whp/194 wtq H23 DOHC
The complete list, from here
http://www.cb7tuner.com/vbb/showthr...=powerful+turbo
Just add your info in a new post and I will update this thread.
Also, whenever I get some dyno time, I will update the numbers for my big 16g setup.
Leave a comment:
Originally posted by 91accordexr33gonna add my f22a numbers
I keed, I keed.
Once my brother has his turbo rebuilt and is tuned/dyno'd, I will post and add his numbers as well.
Leave a comment:
Leave a comment:
