In regards to the topic of discussion I would like to know in terms of reliability how great is this setup actually is because I've found a set of h22 rods that I can get pretty cheap and should definitely have the cash early/mid next year for forged pistons.
A forged piston alternative
Originally posted by d112crzy View PostNo less reliable than any other forged setup. It's all in how you build and spec your clearances.
Originally posted by d112crzy View PostThis pistons sit in the hole. There are no p2v or p2h clearances to worry about.
The clearances you DO need to worry about are p2w, ring end gaps and bearing clearances.
And what exactly are bearing clearances? And p2w means ring end gaps and bearing clearances? Sorry for the noob questions its my first boost build.
P2w- piston to wall
p2v- piston to valve
Bearing clearances...rod bearings and main bearings need to be all at certain clearances(specified in any manual), or else you'll experience oil starvation or rod knock.
ring end gap clearances are is the gap between the rings. These need to also be within limits.
It's all part of rebuilding a motor.
Main bearing journals
Diameter (standard)
1990-1992
Journal numbers 1 and 2-1.9676 to 1.9685 inches
Journal number 3-1.9674 to 1.9683 inches
Jounal numbers 4 and 5-1.9665 to 1.9688 inches
Main bearing oil clearance (standard) 1990
Journal numbers 1 and 2-0.0009 to 0.0018
Journal number 3-0.0014 to 0.0017
Journal numbers 4 and 5-0.0005 to 0.0015
Connecting rod journal
Diameter
Standard
1990-1992.....1.7710 to 1.7717 inches
Connecting rod bearing oil clearance
1990
Standard......0.0008 to 0.0017 inch
Service limit......0.002 inch
Connecting rod endplay (side clearance)
Standard.....0.006 to 0.012 inch
Service limit.....0.016 inch
Originally posted by owequitit View PostI am not a mod, BLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAHBLAH BLAH BLAH.
Personally I know of 3 people gone this route... Its woking out great (One over 500 on stock sleeves). Pull your head out of your ass andf recognize when something for the greater good is being shared, and try not to be a jackass...
Or tell me IM full of shit and dont know what he fuck im talking about too....
You make Chuck Norris sad in the pantsLast edited by Supergenius; 11-01-2009, 11:34 PM.750 WHP/575 TQ CD5 Raping a street near you....
realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
GFI HOLLA!!!!!!
http://www.youtube.com/watch?v=Cdiz0k0Rudw
You make Chuck Norris sad in the pants____
This is an interesting thread. They should replace "Dancing With the Stars" with this reality show.F22a1, T3/T4 turbo, Greddy Type RS BOV on left-over AEM CAI piping, Turbo XS manual boost controller, PHAT intercooler, Crzy tuning, Walbro fuel pump, AEM FPR/fuel rail/pulleys/cam gear, Gude cam and throttle body, MSD ignition/cap/coil, NGK wires and Iridium plugs, Fidanza flywheel, ACT clutch, Nuespeed short shifter
9 lbs on stock internals (for 10 min)
16.2 1/4 mile with basics
??.? 1/4 mile with turbo
139 hp with all bolt-ons
??? hp with turbo
STAY TUNED
you've unleashed a beast now.
his response will add two more pagesLast edited by slammed4thgen; 11-04-2009, 04:50 AM.
smoke tires, not drugs.
