I'm looking to turbo my f22b as soon as I get it installed. I'm going to get my friend's eclipse stock turbo(t25 20K mi) from him for $100, is that a good price? And when you get the 450cc injectors, are you talking about the dsm injectors, or aftermarket? Last thing, I know exactly how a turbo works and all, but I know nothing about the fuel management and ecu. What is chipping the ecu, and why does everyone use the p05 p06 for it? Couldn't you use a greddy fuel management system? although I know it is a lot more expensive.
f22b turbo
http://www.cb7tuner.com/vbb/showthre...light=pressure
that will give u an idea of the fuel management
http://www.cb7tuner.com/vbb/showthre...threadid=10335
i explained practically everything there is to know about chipped ecu's...if u need any help in relation to chipped ecu's ask in that thread but be sure to read it all first
450's are the dsm injectors in most of our cases...easy to install and work great...for $50 u can't really beat it unless they get too small
$100 for a t-25 is a good price. It will spool very quickly but power will die fast also
I'm currently helping another member with the f22b. I will be making a map for the f22b and he will modify it and post it most likely in the next couple of months. Use any management u want just make sure its right for you. My philosophy is if someone else can do it then so can i so thats why i choose to chip a p06 with uberdata and make my own map.Knowledge is power...in EVERY sense of the word
Originally posted by high c
for my f22 turbo all i used was a vafc and some dsm 450's for my feul management and it worked mint. And for like under 300 bucks you cant go wrong!
DSM 450cc inj - $50
Chipped ecu from me - Roughly $110-130 Depending on the ecu price you or i get
Building 6 psi from a stand still - PricelessKnowledge is power...in EVERY sense of the word
one other thing, does anyone know the redline on the p39 ecu? And can you change the rev limiter on the f22a ecu to be the p39 redline? And a question nobody answered, so when I turbo, I can either get a chipped p06 ecu and use uberdata or use a fuel/air controller from apexi. Whats the difference? and in your opinions, what is better?Shift_BOOST
BOOM!
Originally posted by 92ex
one other thing, does anyone know the redline on the p39 ecu? And can you change the rev limiter on the f22a ecu to be the p39 redline? And a question nobody answered, so when I turbo, I can either get a chipped p06 ecu and use uberdata or use a fuel/air controller from apexi. Whats the difference? and in your opinions, what is better?Knowledge is power...in EVERY sense of the word
