So ive decided to go turbo and before that im gonna do A LOT of engine prep, im gonna build a f22a6 and all that jazz. but thats back on topic tho, im thinking of doing a civic Half Radiator and im curious how do you mount that? thanks for the help brah
Mounting a Half Rad
Mounting a Half Rad
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.Tags: None
I relocated the stock lower mounts on mine, and then used one of the stock top brackets to support the top.
http://www.cb7tuner.com/vbb/showthread.php?t=105816Last edited by evil_demon_01; 10-23-2009, 06:49 PM.
My 5.7 LS1 Holden Ute
i took one of my accord Radiator brackets. drilled two holes in the Radiator support frame. sat one of the bottom (civic) Radiator pegs in the accord Radiator peg holder. and used the accord Radiator bracket on the top (civic) Radiator peg.
you want it to fit as tight as possible
it should look like this.
the top one looks easy. just one bracket? is that safe?
Originally posted by J3wman View Postthe top one looks easy. just one bracket? is that safe?
I went to the track this weekend and gotta bad launch. The rad moved outta place a lil but it didnt fall out or anything like that. Just had to take the top mount off, sit it right and put the top mount back on.
how do i mount it so it wont move around a ton?
i see, well... thats a problem cuz i dont have access to a welder. would oxi acetelene welding be good or should i just hunt down a mig welder?
that looks good, wheres the best place for a half rad, i dont trust ebay generics
that's actually what mine is, ebay generic. been holding up for 3 years now.
i only really have overheating problems in 90*+ weather while i'm on the highway doing 70+mph. so i just blast the heat for 2 minutes and it goes back down to normal.
i'm gonna try heat wrapping my mani+DP, as well as other small things, and if nothing fixes it then i'll finally spring for a koyo/fluidyne.
Does it have to be a 2 core radiator? beacasue i read on another thread that some EG radiators come in 1 core only. I am asking because i can easily buy an aluminum one from autozone that has two cores (plus an employee discount!) yay and find a upper rad. support and mount it on the bottom side!
that would work right?
Rip It Up
Sold to: nightime25, MyDianaz06, Accord214 and 408cb7
Bought from:Rob_is_Legend, MonoCB7, Fatboy1185, Flatline and busak87
i vouch for my Brothas
i wouldnt trust a single core cuz its so small i was thinking maybe a tri core half rad would work well
Originally posted by J3wman View Posti see, well... thats a problem cuz i dont have access to a welder. would oxi acetelene welding be good or should i just hunt down a mig welder?
Originally posted by Extacee View PostDoes it have to be a 2 core radiator? beacasue i read on another thread that some EG radiators come in 1 core only. I am asking because i can easily buy an aluminum one from autozone that has two cores (plus an employee discount!) yay and find a upper rad. support and mount it on the bottom side!
Theres nothing wrong with using one bottom mount.
