just added a 60 a/r 63 trim turbonetics to my list...lol
G22 turbo build
New paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
Motivation is one of the keys to life....tell me "can't" and I wll show you I can
Originally posted by Gtseviper View PostI grinded down some hex head bolts and literally slammed them down into the two unnessary head drain ports....the gasket I used fit perfect with the ports and also helped cover the un-needed drain ports
I got some headless screws and grind the edges off because they were to big...but i left enough to use an adjuster tool (hammer) for a tight fit...then I slammed headless screws into the un-need drain holesNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
I hammered them into the head.....
I finally got my engine aligned in the bay...
94 tranny, g22, f22 mounts all around including 90-93 manual bracket...I just tapped the new required holes for the 90-93 tranny mount..and everything works greatNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
Originally posted by Gtseviper View PostI hammered them into the head.....
the preferred method is to tap the holes in the head with a pipe tap and buy 2 hex head pipe plugs and seal them into the head with hondabond or the like....
I used high temp silicone around the bolt before I slammed them inNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
alright guys...I have started the engine at it runs great....now I just have to finish fab up the exhaust system then I'm tune with cromeNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
alright guys...I had a major oil problem...since this was my first time doing an engine...I didn't do the valve seals correctly...so oil leak into the intake manifold runners and exhaust manifold and piston area...I'm about to send it to the machine shop to have it redone...till then...I'm going to order a new headgasket...and I'm actually using the h23a headgasket which works perfectly with the f22b to h22a4..I have to look at the t4/t3 to because it doesn't spin freely with the idle exhaust air...but If I put my hand to turn the wheel...it feels smooth with minor touchingNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
yeah...I'm a pro now...I pullled it twice
...one to realize I had the headgasket in the wrong direction that two for the valve seals
..everything else works great though..and I fixed all but one leak...the oil pan has a hair pin leak...WELDDD..lol
I'm about to put up some more pictures
I was surpise to see how quick the engine start on that p30 map with h22 map numbers...I followed the xencron crome map setup and it worked like a charmNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
new photos addedNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
I got the head back from the shop...now i shall continueNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
