SpeedFactory F22A Turbo Manifold
    http://www.facebook.com/speedfactoryracing?ref=stream
    Like them on Facebook for more information.
    Wow that looks good!!!
    Accord Of The Month January 09
    Accord Of The Year 09
    My 2 Babys
    BMW TECH FOR 15 YEARS
      I want!
      Lol @ The comment about the Bisimoto knocks
      8 Accords so far:
      '81 SE Sedan(1st Gen), '83 SE Sedan(2nd Gen), '89 SE Sedan(3rd Gen)
      '89 DX Sedan(3rd Gen), '92 LX Coupe(4th Gen), '92 EX Wagon(4th Gen)
      (3rd gen parts car) I'm currently Driving a '14 Accord Sport 9th Gen
        You couldn't pay me enough to get a Facebook account; what's the Bisi comment say, you have me curious?
        Accord Aero-R
          "Better weld your name on it SF before Bisi Moto gets at and makes it his own lol"
            Clean welds, compact design... but it is really that much different from a quality log manifold?
              shiny
              C-3PO's MRT USDM yo!
                yes. it is much different from a log manifold. In power, efficiency....everything.
                www.850fab.com
                IG - @850Fab
                FB - @850Fabrication
                  What makes it that much better?
                    The fact that when cylinders 1 & 4 fire their exhaust gasses don't pass by existing exhaust ports 2 & 3 when being exhausted?
                      AKA Min Ram.....Manifold looks identical to my KS built one, witch is holding 650+. Very cool that Speed Factory has these off the shelf for our engines now Deev its a lot better....log manifold have horrible waste gate placement, doesnt have a collector for smoother flow, it causes boost spike, and EGT's will be hotter. Log manifold also has a lot sharper 90° angles, just more of a bottleneck restriction than a tubular mini ram.
                      MRT H22A - 302whp - N2O
                      MRT F22B - 643whp - 529tq @ 30psi
                      11.33 @ 131mph @ 27psi
                        I'm asking more for the fact that having such detailed information on WHY people should want this (other than the fact that it's shiny) rather than out of my own ignorance. I do know a thing or two...
                          I'd like to see this installed. I'm curious what kind of clearance there is between the alternator and compressor housing when running a T4 .70A/R compressor.
                          I don't see a wastegate flange on this example...what kind of wastegate options are there for this manifold?
                          SOHC Non-VTEC F-series for life
                          "It is the fools prerogative to utter truths that no one else will speak."
                          -Morpheus (The Sandman)
                            Those 4 pipes don't merge. I don't know of any turbo with an inlet THAT big... so I'd assume a collector would need to be added to this as well. In doing that, the position of the turbo would depend on the length of the collector. I could see it plopping the turbo easily where the AC compressor should go (which would be a convenient location.)
                              It might not be equal length but they do merge into a collector -
                              I also have a .70A/R compressor on my 6262 in my car but I dont have this design manifold so I cant be much help to say if you can even run a air filter with this manifold. Also the mounting flange off the collector in the picture is not welded yet so I assume this is not finished and they still need to add a wastegate flange as well.
