so i've looked into it and the 93 coupe just may be going boost. i have rods left over from my last build and a set of h23 headstuds i just bought brand new with acl rod and main bearings for $75. so a set of 9:1 pistons and an overbore coupled with a custom regrind and it'll be set. i may be able to boost it for around 4k and i'll just throw the t2w4 on betsy and the m2s4 in the 93 coupe with the 4.062 FD and a lsd. it already has coilovers and new bushings so who knows. the turbo i plan to use is the borg warner EFR 7076 .92 a/r with built in wastegate and recirculatory valve, you know this guy vvvvv
coupled with one of these little guys minus the wastegate flange
i think with a good set of 1000cc injectors, 3" exhaust, proper intercooler sizing and it should be fully capable of 400-500whp. the way i see it is if i can make 180whp on motor at 14.7psi atmospheric pressure it should produce 500whp at roughly 26-28psi with that turbocharger. dont get the wrong idea from this either. to all my n/a f-series followers betsy will stay on track for a 2.6L stroker street build. right now im having a hard time finding someone i trust to take a 100mm brian crower stroker crank and properly machine it down with an offset to fit f23 rod journal bearings. the expensive part will be the crank. i think about 5k and the bottom end will be good to go. but this year my budget is slightly limited so i figure why not finally toy with the 93. i haven't even made a MRT on it yet. it just kind of sits there and gets drove about once every two weeks. it does make me enjoy betsy more after i drive it. considering it is stock with ebay bolt-ons and the stock f22 trans. it is a massive difference. betsy can litterally walk off and leave it from a 60mph roll with betsy in 5th and the 93 in 3rd. proof is when i took it to get an alignment last week, i picked it up and my girl was driving betsy and i was in the 93, i dropped it down to third and rolled up on besty and she didnt even downshift and she just waalllkkked away. i was really surprised, betsy is so composed when it is accelerating that it doesnt feel that fast. you really can only judge it by the scenery or the speedo. if things go well over the next couple of years and i get both cars completed i will be testing n/a vs turbo to the fullest extent, lol.
