Originally posted by CBL
92HondaEX Official Turbo Project Thread.... (56K Warning)
I wanna see some Mustang GT's being spanked!
By the way.......Have you considered using Crome as your tuning platform?
It works off the ECU, but has all the goodies you'd expect at half the price of uberdata or Hondata. I use it on my Turbo Civc and it works wonders.
Let me know if you want to do some research on it, I'll give you a link for the website.
Awesome work, by the way! Giving us CB7 guys hope around the world.14 Ford Focus ST - stock(ish) - E30 Tune + Green Filter =
Here's the link for the housings if you wanted to see for yourselves...
http://64.225.76.178/catalog/thousing.html#t3
correct me if im wrong but uberdata is free... well at least i downloaded a version off the internet. Maybe i downloaded an old version so it was free. I dont know... lol cant be half the price if uberdata is free...Last edited by MRKIKKOMAN; 12-15-2005, 04:06 PM.DIY antenna control
DIY ghetto short ram
Battery Relocation
New Project
1984 BMW 533i =DEAD
I was messing around with some turbo calculation and this is what I came up with(based on stock f22a sohc):
([2156/16.387] × 6200) ÷3456 = 236.03004cfm (air flow at 100% VE)
236.03004cfm × 0.85 = 200.62553cfm (air flow at 85% VE)
[10 + 14.7] ÷ 14.7 = (1.68:1 pressure ratio)
__________________________________________________ _______
T2 = T1 (P2 ÷ P1)0.283
°R = °F + 460
T1 = 75 + 460 = 535°R (assume outside temp was 75º)
P2 = 14.7 + X (X is pounds of boost planned)
P2 = 14.7 + 10 = 24.7 psi (with setup at 10psi)
T1 = 75
P1 = 14.7
P2 = 24.7
T2 = 535 (24.7 ÷ 14.7)0.283 = 620 °R
You then need to subtract 460 to get °F, so simply do this:
620 - 460 = 160 °F Ideal Outlet Temperature
This is a temperature rise of 85 °F
Ideal Outlet Temperature Rise ÷ AE = Actual Outlet Temperature Rise
85º ÷ 0.7 = 121 °F Actual Outlet Temperature Rise (at 70% adiabatic efficiency)
Now we must add the temperature rise to the inlet temperature:
75º + 121 = 196 °F Actual Outlet Temperature
(Inlet °R ÷ Outlet °R) × (Outlet Pressure ÷ Inlet Pressure) = Density Ratio
(535 ÷ 620) × (24.7 ÷ 14.7) = 1.44990 Density Ratio
Outlet CFM × Density Ratio = Actual Inlet CFM
200.62553 x 1.44990 = 290.88696cfm
290.88696 CFM × 0.069 = 20.07120 lbs/min
__________________________________________________ ________
Now you can use these formula's along with flow maps to select a compressor to match your engine. You should play with a few adiabatic efficiency numbers and pressure ratios to get good results. For twin turbo's, remember that each turbo will only flow 1/2 the total airflow.
Last updated 12/28/02
Turbo Type ----------- Approx flow @ pressure
Stock Turbo ---------- 360 CFM at 14.7 PSI
IHI VF 25 ------------- 370 CFM at 14.7 PSI
IHI VF 26 ------------- 390 CFM at 14.7 PSI
T3 60 trim ----------- 400 CFM at 14.7 PSI
IHI VF 27 ------------- 400 CFM at 14.7 PSI
IHI VF 24/28/29 ----- 410 CFM at 14.7 PSI
========= 422 CFM max flow for a 2 Liter at .85 VE pressure ratio 2.0 (14.7 PSI) 7000 RPM =======
IHI VF 23 ------------- 423 CFM at 14.7 PSI
FP STOCK HYBRID -- 430 CFM at 14.7 PSI
IHI VF-30 ------------- 435 CFM at 14.7 PSI
SR 30 ----------------- 435 CFM at 14.7 PSI
IHI VF-22 ------------ 440 CFM at 14.7 PSI
T04E 40 trim -------- 460 CFM at 14.7 PSI
========= 464 CFM max flow for a 2.2 Liter at .85 VE pressure ratio 2.0 (14.7 PSI) 7000 rpm =======
PE1818 -------------- 490 CFM at 14.7 PSI
Small 16G ------------ 505 CFM at 14.7 PSI
ION Spec (stg 0) --- 525 CFM at 14.7 PSI
========= 526 CFM max flow for a 2.5 Liter at .85 VE pressure ratio 2.0 (14.7 PSI) 7000 RPM =======
Large 16G ----------- 550 CFM at 14.7 PSI
SR 40 ----------------- 595 CFM at 14.7 PSI
18G ------------------- 600 CFM at 14.7 PSI
PE 1820 -------------- 630 CFM at 14.7 PSI
20G ------------------ 650 CFM at 14.7 PSI
SR 50 ---------------- 710 CFM at 14.7 PSI
GT-30 ---------------- 725 CFM at 14.7 PSI
60-1 ----------------- 725 CFM at 14.7 PSI
GT-35R -------------- 820 CFM at 14.7 PSI
T72 ------------------ 920 CFM at 14.7 PSI <--- Note you would have to spin a 2.0 L engine at about 14,000 rpm to flow this much air.
IHI VF 25 ----------- 395 CFM at 18 PSI
IHI VF 26 ----------- 400 CFM at 18 PSI
T3 60 trim ---------- 410 CFM at 20 PSI
IHI VF 27 ----------- 420 CFM at 18 PSI
IHI VF 24/28/29 -- 425 CFM at 18 PSI
IHI VF 23 ----------- 430 CFM at 18 PSI
IHI VF-30 ----------- 460 CFM at 18.0 PSI
AVO 320HP -------- 465 CFM at 17.5 PSI
T04E 40 trim ------ 465 CFM at 22 PSI
FP STOCK HYBRID- 490 CFM at 18.0 PSI
IHI VF-22 ---------- 490 CFM at 18.0 PSI
SR 30 --------------- 490 CFM at 22 PSI
Small 16G ---------- 490 CFM at 22 PSI
ION Spec (stg 0) - 500 CFM at 19 PSI
PE1818 ------------ 515 CFM at 22 PSI
Large 16G --------- 520 CFM at 22 PSI
========= 526 CFM max flow for a 2 Liter at .85 VE pressure ratio 2.5 (22 PSI) 7000 rpm =======
========= 578 CFM max flow for a 2.2 Liter at .85 VE pressure ratio 2.5 (22 PSI) 7000 rpm =======
HKS GT2835 ------- 580 CFM at 22 PSI 400 hp
MRT 400 ------------ 580 CFM at 16 PSI
AVO 400HP -------- 580 CFM at 17.5 PSI
MRT 450 ------------ 650 CFM at 19 PSI
AVO 450HP -------- 650 CFM at 20.0 PSI
SR 40 ---------------- 650 CFM at 22 PSI
========= 658 CFM max flow for a 2.5 Liter at .85 VE pressure ratio 2.5 (22 PSI) 7000 rpm =======
HKS GT3037 ------ 670 CFM at 22 PSI 460 hp
PE 1820 ----------- 680 CFM at 22 PSI
20G ---------------- 695 CFM at 20.0 PSI
HKS GT3040 ----- 710 CFM at 22 PSI 490 hp
AVO 500HP ------ 770 CFM at 22 PSI
SR 50 ------------- 770 CFM at 22 PSI
GT-30 ------------- 790 CFM at 22 PSI
60-1 --------------- 800 CFM at 22 PSI
HKS GT3240 ----- 830 CFM at 22 PSI 570 hp
GT-35R ----------- 880 CFM at 22 PSI
T72 --------------- 1000 CFM at 22 PSI <--- note you would have to run a 2.0 L engine at >40 PSI boost to flow this much air
Conversions used where there was control over conversion factors:
1 HP approx equals 1.45 CFM
1 CFM approx equals 0.0745 lb of air/min
0.108 Lb/min approx equals 1 hp
1 Meter cubed/sec = 35.314 CFS = 2118.867 CFM
1 KG/sec = 132 lbs/min approx equals 1771.812 CFM
power coversions:
1 PS = 0.9859 HP = 75 Kgf m/sec
1.3405 HP = 1 KW
1 HP = 746 wattsAttached Files
Originally posted by WiccanvampierWell, a divided housing would help spool up a bit, but the 76trim 1.32 a/r is absolutely massive. I just say good luck.
-Kyle
Two things....first, I just got my turbo. I know ya'll want pics, but just hang one for a second, ok?
Secondly, I'm adding the link of the base map(thnaks MRX, even though he probbly doesn't know I'm gonna use it... ), but here it is....
http://uberdata.pgmfi.org/forum/atta...urbof22v25.bin
