Lowcords official boost thread
    DP angle is the same too lol, i ahd t25 first and then a 16g and no problema. my car never got 30 mpg. its very weird but my gas milage didnt decrease by much. maybe like 3-4mpg
    h23a3 cb7 turbo sold
    FS: 1 Piece JDM Headlghts blackhoused
    My Members Ride !
    New ride
    '07 GTI Mk5 6spd
      did you adjust the fuel curves?? bigger turbo needs more air and more fuel... you can't run a 16g on a dsm with 440cc injectors. well actually you can, but i wouldn't... the oil lines are different too
        umm yeah adjusted fuel curves a little, who said u cant do 16g with 450cc's lol. as long as you keep the boost at 10-12 you're good to go oil lines are teh same >> the fitting that goes into the turbo is different.
        My Members Ride !
        New ride
        '07 GTI Mk5 6spd
          10-12 on 450s?? craziness.. as long as you have a way to watch your knock you should be straight. and you cb7er's have convinced me to ditch the 14b idea and go with a 16g.
            Screw that, get a 60-1. You got a factory turbo motor...lol.
              lol i would if i didn't have that car as my dd....
                lol yup thats what i run 10 psi daily. i have no boost controller to eliminate temptation..... 10 is what the WG is set to on the 16g.
                My Members Ride !
                New ride
                '07 GTI Mk5 6spd
                  ok now back on point here is an update of progress.
                  the cold side is completly plumbed in
                  the hot side as far as i can go until i get the ecu from eric then ill plumb the rest in had to remove power steering and cruise to fit the piping in the way i wanted it. 18's+no P/S= learning to drive all over ..lol its really not that bad
                  these arent the best pic but it does the job for now
                  incase anyone was wondering my front is messed up cause i hit a deer carcus on the interstate and it broke the kit in half so now im in the process of glassing it together wich is no biggy thats what i love about fiberglass its so easy to fix and change so now everthing is wired and plumbed jus waiting for the ecu to complete everthing else.
                    The 18's and no p/s aren't as bad as I thought they would be..that's what I have too. I would have been pissed about the deer though. I hope you at least got out and kicked it a few times even though it was dead.
                      the shocking thing was i got the entire car over it without blowing out my rear ???? amazing is all i had to say about that my car is only bout 4 in of the ground so i really lucked out. what happend was i was fallowing behind a truck doin bout 75 then i see blood spatter like a deer got hit then all of a sudden out from under this truck is this dead deer carcus i could even get over cause a car was next to me so i jus had to take it luckily the intercooler wasnt put on till later the passanger side floor was bumped up but i was able to hammer it back down so that was no biggy so like a said the amazing thing was that all it did was break my front. i dont know what was worse though hitting it or smelling the peices that got stuck on me exhaust pipeing.
                        wow dude. but hey i personally am not into kits, reprase that ... kits on our cars lol with nothing to fill that huge jdm intercooler space . but ive yet to see a bumper like urs. i think it will pretty hott when its painted and that big boy intercooler def makes a statement lol. good luck on ur proj.
                        My Members Ride !
                        New ride
                        '07 GTI Mk5 6spd
                          thanks thats what i kinda set out to do when i bought that intercooler that and i thought it would jus look cool to fill up that whole center gap wit shiny intercooler
                          also quick questoin dos anyone know the part number for the ngk 1 step colder spark plugs?
                            It's exactly like stock except with a 6 instead of a 5 for the heat rating. On NGK plugs they get colder as the number goes up.
                              thanks for the info ill prob order them friday from autozone i doubt that they actually carry them around here
                                just a quick update i was installing the turbo last night and everything was runing great and LOUD i didnt have the downpipe on. but i noticed a little oil leaking coming from the t fitting in the back so i start to feel around and i touch the line that goes from the T to the turbo and bam it jus breaks off the fitting broke from the line and oil spued everywere. Sucked that was like 3am so i called it quits and tonight i think im goin to get some fuel line and use that as a temp fix to conect the problem area.
