warming up and cooling down
    jus wondering what you guys do, do you jus hop in the car and go or do you let it warm up a bit and how long do you let it cool down after driving. Ive got a blitz turbo timer but the instructions are in japanes so its taking me awhile to figure it out...lol but like i said jus curious as to what other turbo cb7 are doin cause i want to take as good of care of my turbo as possible
    as for warming up i let it get off cold before i get into it, and for cooling down i leave my timer on 2 to 3 mins for around town and up to 5 to 7 mins if ive really been getting on it. I dont think you can leave it on too long the better it cools the longer the life of the turbo. Or at least thats what i understand.
      warming up- I let it sit till the idle stops bouncing around
      cooling down- 2 min normal driving(which is never) OR 4 min after racing
      Shift_BOOST
      BOOM!
        slight vacuum leak do you have enugh coolant? any cells?
          i don't have a boosted car currently but have in the past. but regardless of boosted or not i have treated every car i have owned the same way on warm up. a little depends on the car as some idle high when cold and some don't. either way I always let them run a little before ever putting the engine under load(before i leave my parking space basicaly). for example my jeep doens't really idle high so i jsut wait for the temp needle to start moving. my accord i wait til the idle gets down to at least 1300(usualy starts around 1800 and creeps down). at say 40 degrees outside this is about 3-4 minutes for either vehicle....takes longer when real cold out and shorter when hot out. then I pretty much baby them til they are up to full operating temp. and are there for a little bit jsut to make sure everything is nice and warm. jsut cuz the combustion chambers has heated the water according to the guage doens't mean the bottom end is hot!! neither vehicle sees over 2000rpm til then. some might think it's anal but it has worked for me and i've had pretty good luck with it....no major engine failures and way more miles than most out of my engines. sold my 96 camaro 2 months ago with 191K on the original LT1.....and trust me it was not babied after it was warmed up!! also had a 4 runner that now has 225k on it, wifes van has 170K, jeep has 146K. gotta be nice to them engines when they are cold!!
          Donny O.
          90 Accord EX...daily driver
          toys:
          99 Hugger Orange Camaro SS convertible
          98 Jeep wrangler...small lift/big tires
          95 CBR900RR
            It's the ecu, and for some reason I can't adjust it. It idles too rich, I'll lean it out, and it won't start. It bounces from 1000-2500, no leaks, no CEL, nothings wrong, just the way it is. That's only on a cold idle, warm idles pretty good, I'm sure I could fix it by switching to UD 1.7, but it works so I'm not complaining.
            Shift_BOOST
            BOOM!
