Question on DSM Manny
    What size drill bits did you guys use to enlarge the hole? 5/16 looked too small, but 3/8 looked to big! Any help would be appreciated!
    i used a die grinder with a carbide cutter and enlarged as neccisary
    instagram @mikeymeyagi
      Unless your using a drill press, don't drill it....it's so easy to slip and get a body part.
      My official vouch thread!
      Updated!!! --> My official turbo progress thread
        Even so, I used an angle grinder on the end one and then filed with a sharp round file! It took a little elbow grease but still a cinch!
        WaC!
          i use a dremel
            I never thought about using a dremel. A mechanic I work with has one that I can use. What accessory did you use to do it with?
              A carbide cutting bit..
              It takes a loooooong time. if you can do it by any other means i would highly suggest leaving the dremel as a last resort
                Does it matter if I get the holes too big? Would that cause an exhaust leak?
                  Well all depends on how big, but you could use some washers to help secure the castle nuts!
                  WaC!
                    mmmm white castle....
                    www.myspace.com/sajunglist
                    www.bassdrive.com
                      You know how big you have to grind the hole to get a leak? Get a f22a gasket and mark the holes...just don't go any bigger.
