Ok, first of all, refer to my members ride thread at the bottom for tech specs on my car, to get an idea.
What i'm looking to do is get a turbo off a friend of mine, because he is parting out a 1990 GSX. It's my understanding that I should be able to use most of the turbo setup from that car, just redrill the manifold, and it should work. anyways.. my question for you guys is what do you think about the following setup, on an extreme budget....
DSM stock 14b turbo/manifold with piping and side mount until i get the piping for the front mount that i'm being given. Not sure of an exhaust off the header, i'll have to do more research for that. So all that, running maybe 6-8 p.s.i., and my ZEX wet 55 shot. Add to that bigger injectors, and an FMU. Does all this sound reasonable so far?
I'm not a turbo guy, so i don't know alot about building a turbo car. I just figured this would be a good idea, try it out, and if i blow the motor, drop another f22a1 in for a couple hundred, although i'd like to not blow the motor. obviously also i need oil pressure and return lines, which i can grab off the DSM as well. As far as exhaust off the turbo, i'm not sure how that works, and if someone wants to shed light on that, thank you, otherwise i'll research and find it like a good cb7er.
i'm getting the turbo/manifold/piping/ pretty much whatever i need for $50, so i'm thinking it's gotta be worth it. but let me know what you guys think or if you have a better idea.
