innovate LC-1 since i can just datalog with my comp
Summer Turbo Project
fixing the fitting dilemma this morning, going to go out and find the right size thread fitting... while im at it i figure i might as well run the coolant lines, so ill pick up some fittings for that too while the turbo is easily accesible. wideband is in this morning, but havent gotten a chance to datalog as i havent run the car yet.... all in good time.
and i swear, if this thing leaks ANY oil by the time im done with it, im finding the biggest bridge around, and driving it off of it.1993 CB7
2001 BB6
car runs great, smooth powerband, and completely smooth idle at about 800... im really happy with it.... im gonna spend the rest of the day smoothing the map and tuning with the wideband... i drove the car 2 hours on the freeway yesterday with no problems... leaks NO oil now, engine temps were good... but heres the riddle... i havent hit 8 psi yet, but i think im having wastegate probs... either i cracked the flapper or the rods stuck... to my knowledge i havent hit the point where the WG opens, but since about halfway through my drive yest, the turbo doesnt even spool till 3500, and weak at that... as in i cant even hear the BOV...i rechecked for boost leaks, and the pipings fine... so im thinking the WG is stuck open, or the exhaust housing is cracked around the WG, ill inspect later today...
other than that, ive been taking it easy on the car... couple Spec V's and a mid 90's mustang gt on the kill list already, and only at ~4psi before i let off... cant wait to safely push 8
thanks to everyone who helped out, all you guys on the site, couldnt have done any of this without the help!1993 CB7
2001 BB6
not to revive a dead thread...
popped the hood today to check on everything, ive been trying to finish tuning the vac section so im not running overly rich.... anyways, i noticed the breather filter on the left side of the valve cover (the one that goes to the stock intake) is saturated in oil, and theres some oil spackled all over the engine bay, im about 1/2 quart down too, and this is the first time ive noticed this... any ideas to the culprit?1993 CB7
2001 BB6
Originally posted by bresk8r87yeah, havent had any internal problems so far, i guess its just normal blow by thats started accumulating since the cars been boosted, i was just missing it... id be much more worried if i was seeing any symptoms of ringlands going, etc.
