Summer Turbo Project
    just get rid of ps then, its not that hard without it. you'll get used to it.
    90EX fit a 3" think fmic. he had to cut the bumper and bumper support, but it fits like a glove and you cant tell its huge.
      ive had no PS before, and i didnt like it, it wasnt exactly hard to keep it, i just looped the two pipes for the cooler with some PS hose and clamped them....i still have room to mount the cooler above the IC if i feel like it later...since the bumper fits perrrrfectly over the IC and i have room up there still....
      1993 CB7
      2001 BB6
        ecu comes ships tomorrow. ill know if its my problem by the end of the week. car is put back together, but is still running on stock ecu with cold side pipe disconnected so it runs NA... ironic... anyways....im gonna go wash it now and take some pics...
        1993 CB7
        2001 BB6
          once you get your car running, have you contemplated running water injection?
            just some pics.... havent washed the car, going to the exhaust shop in the morning and then washing and detailing.
            1993 CB7
            2001 BB6
              so today i drove the car to the gas station N/A and open downpipe, and filled the tank, and leaving the gas station it wouldnt start... almost like it was flooded...
              ive got the 450's in still, and im running the stock PT3 for the time being (coldside pipes not connected, with a filter on it)
              my question is, why do you think it wouldnt start? dumping too much fuel? i let it sit for a good 10 minutes and the same old story...car turns over but doesnt start. i really hope i dumped too much fuel and i didnt do anything to the engine my bud had to tow me home
              when i pulled the plugs last week to check for compression, they were black from running so rich, so i guess theyre now so covered in shit that im not getting a spark to start the car? im gonna pull them in the morning and replace them with one step colder anyways....hopefully thats my problem
              anyways, let me know what you guys think
              1993 CB7
              2001 BB6
                did u try starting it with your chipped ecu?
                  no...the ecu is giving me problems and not accepting the chip, so im waiting on another p06 to arrive... the p06 ran on the stock map with or without the chip in, and even after i checked connections and soldering it wouldnt work, so i just have the car running na right now on the stock ecu (which is why im running insanely rich)
                  EDIT: i just went outside and started the car, and it started right up...roughly, granted, but no hesitation...seems i hit the nail on the head... new plugs and a bottle of injector cleaner should fix it... whew
                  1993 CB7
                  2001 BB6
                    your shift boot = sex
                    Anyway, thats how u solve problems. By yourself.
                    Good job.
                    YouTube Clicky!!
                      are you going to run a heat shield?? are you going to run an open turbo?
                        turbo now has a screen clamped to inlet... and i ordered some heat wrap for the mani, my main concern is wrapping the downpipe in it because the oil return sits so freakin close to it and i dont want to melt it
                        EDIT: chipped p06 will be here in the morning!
                        The guys at Intec racing are really cool, the rep i dealt with is overnighting it to me for no extra charge . they tune with crome but the guy burned me a map for a small t3 f22 setup once i told him my setup, and he said its a pretty damn strong basemap...so looks like ill be experimenting
                        1993 CB7
                        2001 BB6
                          so, i either have a very dead battery or something is fucked. i started the car today, and it will barely turn over (got very sluggish) and now just wont start and clicks...i know, dead battery. when i jumped it and got it running, as soon as i let off the gas, it died...like instantly.... any ideas?
                          1993 CB7
                          2001 BB6
                            Are you still running the 450 injectors N/A? That could be the problem, try temporary adjusting the idle
                            I'd eat a baby for free. I'm hungry, dammit!
                              its nothign to do with the injectors, i could run the car rich all day before it started to bog. this is instantaneous.
                              im running with turbo connected and MRX's basemap...my only guess is its a drained battery from sitting for 3 weeks, and me starting it alot without letting it recharge...guess ill know when i take it up to get tested in a few
                              1993 CB7
                              2001 BB6
                                just spent a bit playing with the car in neutral, trying to see how the maps work with my completed setup....anyways, i revved a couple times, and then all of the sudden my engine bogged down and died...and didnt have enough juice to restart it...due to a drained battery....
                                i went to pep boys, charged the battery, and headed back to see if that was the extent of my problems...
                                well, upon pulling the plugs (which i replaced before even starting the car...
                                ) they were black and wet. i was too panicked to see if it was fuel or oil, im hoping fuel from being rich...but im on mrx's 14b map so it wouldnt really make sense to be running that rich at idle....
                                white smoke coming out the exhaust housing (still open downpipe) just did an emergency comp check and compression checks out at 175, 175, 175, 175... so i havent ahceived my worst fear yet... it idles alright now (warm is around 1000), but as soon as i gas it, it starts missing pretty violently around 2400rpm, and has a mind of its own...ill let off the gas and it will surge for a second and then drop back to normal idle...
                                im still not even out of vaccum when i punch the throttle too... so i know ive got some bad boost leaks, but those are the least of my worries at this moment...
                                so i dont know what the deal is... if this keeps up, im pulling the kit and parting out, ive outspent myself on this project as it is, and i really dont need a blown motor on my hands too...
                                im going back to school next week, so im thinking worst case scenario, ill slap the stock injectors on, unhook the charge pipes again, plug in the PT3 and drive down there stock...then try and figure out what my problem is... i know its not on the map's end....
                                will update when i try to get it running in the morning.
                                1993 CB7
                                2001 BB6
