Coolant lines running to the turbo
    I was wondering where abouts can I route the coolant lines to the turbo and where to return it?
    thanks in advance
    I am assuming you mean oil feed & return??
    Keep Pushing..
      Nope I mean coolant like water coolant, the turbo I have is water and oil cooled
          I use the ports on my thermostat that use to feed the throttle body.
            Thanks for the info Raf, would that be a feed to the turbo or be the drain?
              Both. These lines previously fed coolant to the TB, in and out. Low pressure line too. If you're serious and need some pics let me know or PM me
