Ok last night me and my friend were messing with the setting for the safc. got the car running better. still need to fine tune it though with the wide band. so we look and theres smoke from the front (turbo area) the manifold was glowing cherry red. it was just a small section. right before it merges to the wastegate flange but that wasnt cherry red. it was just a section of at least 2 inches to 4 to most. it was so hot the return line melted away. is there a reason why it did that? why only that spot and nothing anywhere else? where can i fine a stainless steel return line at?
New Server Migration
Hello everyone, Pandemic here. I wanted to let everyone know that we're working on migrating to a new server which will allow for more update flexibility including SSL certifications. The old box is really old and it's been time to find a new one for a while.
Data was migrated to a the new box a few weeks ago. We're working on testing the page to ensure it actually works before we go live. If anyone has any web development or coding experience and wants to help, DM me.
Thanks!
Thanks!
Red Hot Manifold?
sounds like either your timing is way off, or your running lean....
can i ask though, with the abundance of information about boost on this site, why are you using an AFC for tuning? it might be advancing your timing (sorry, it IS advancing your timing), causing excessive heatLast edited by Accord R33; 06-26-2006, 11:02 PM.
hence the predetonation larry...
wanna borrow my chip burner?? hehehe...
this the manifold that im running. right where the wastegate flange is thats where it was cherry red hot. im talking to a friend of mine that knows alot about turbos and tuning. he straigt told me to use the afc and not use a chipped ecu. ive done my research alot on this. on the air/fuel ratio guages its running between lean and stoich. more towards stoich. on the afc its running 14.8%a/f ratio.
Originally posted by KillerCam282Stoich while in boost? Now that is something I would love to see a Honda do! Hell some factory turbo'ed cars don't even do that! Lets not jump the gun tho. Does he mean while going WOT? If so, tell him to stop touching your car.h23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
If your running turbo rich would be on the safe side. As mentioned stoich WOT is just bad lol bad things WILL happen. You sure your using the AFC right? Best way to use it is on a dyno but that costs money and every setup is diff.
Originally posted by KillerCam282Is it because this thread can quickly turn into, "Why did my engine blow to bits and pieces?"Knowledge is power...in EVERY sense of the word
